I think all bearings and pinion seal for the final drive/diff assembly are the same for either early AE86 T series or late AE86 T series or TE71/TE72.
The only differences for the late and early T series stuff (change over at October 1985) is the axles themselves, and the diff sidegears, due to the different spline.
All the bearings and housings remain the same. But there is still the options of disk/drum and LSD/open diff across the range.
As for part numbers, why not just go to Burson or Repco and get them to order stuff for a car with T series diff. Such as TE72 T-18 SE for example.
You should be able to do this with almost every mechanical part you need.
