Results 1 to 10 of 60
Thread: Welcome to New York
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Default Welcome to New York
    Hey
    Yes
    I am ready
    Senior Member Zane k's Avatar
    Aug 2011
    Zane
    Gold Coast
    Ahhh! You bought clintons wagon? Plans for this?
    TailorMade☆DC
    20v 4AG Corolla:
    Jacob
    Sunshine Coast
    Small block Chev
    Blower out the bonnet
    Holley carb
    Custom nos plate
    200 shot
    Shortened 9"
    Drag slicks
    2 speed power glide w/ trans brake
    Should be good for 9 sec quarters
    Veteran drift kid's Avatar
    Glossodia
    What about the wheelie bar!!?
    Jacob
    Sunshine Coast
    And number plate relocation for the shoot
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    MF'er
    Veteran stahlz_ae86's Avatar
    Paul
    Good to see this car is still around.
    Senior Member declan's Avatar
    Declan
    Semaphore
    glad to see this is in good hands :*
    Jacob
    Sunshine Coast
    Is what I'm pretty sure mum says whenever she leaves her house via the front door.
    Jacob
    Sunshine Coast
    Pretty sure this is all still mostly correct
    Cusco front strut brace
    Cusco Camber tops
    AJPS helper springs
    KYB AGX 4 way adjustable shocks
    AJPS 8kg Springs
    Custom Compact Coilover sleeve
    JDM cailpers rebuilt with new seals
    Braided brake lines
    A1FM Pads
    New slotted/vented disks
    New wheel bearings and wheel studs
    XT130 Lca's with super pro bushes and new ball joints
    AJPS 40mm RCA's
    Rose Jointed tie rod ends
    Cusco Caster arms w/ Cusco mounts
    Cusco Swaybar (23mm i think?)
    Cusco Caster arm brace
    REAR:
    Stock S series leaf sprung diff
    Reset leaves
    KYB excel G shocks
    Interior:
    JDM ae86 seats
    bed in the back
    Interior is all black
    AE82 twinky wheel
    Modified instrument cluster with Omori water temp and Autogage tacho
    Omori Vacuum, volts, exhaust temp, oil temp and oil pressure mounted into dash cluster
    JDM ae86 fuel pedal
    Engine:
    None, got a 4AGZE w/ SC14 lined up to chalk second at the lights with one wheel
    Exterior:
    Full respray
    JDM diesel front end
    All guards hand flared
    Panels cut out and replaced with Genuine jap windows/seals
    Genuine JDM electric fender mirrors, not wired up though
