for sells uncomplete project adm ae86
4age silvertop 20v
the rebuild is as follows (hopefully i included everything) :
toda over sized high compression forged pistions C/R 12:5:1
H beam forged condrods
ARP head studs
ARP crank studs
Kelford 194-C racing cams
Toda racing adj. cam gears
Full head reco port and polish
Supertech 1mm over size valves
Supertech racing vavle springs
Tomei crank caps
TRD 0.8mm multi layer metal head gasket
TODA timeing belt
1zze Coilpacks
ALL ENGINE PARTS BALANCED
ITB'S (trumpets)
+ all RWD conversion parts
Fuel system -
Bosh 070 internal pump
Bosh 040 external pump
surge tank
other mods
T-series diff with TRD 2way + 4.77 final drive
Haltech PS1000
Fully adjustable coilovers with camber in front
AE86 6KG springs on the back
T50 Gearbox
Fully adjustable recaro racing seat
jdm ae86 calipers, 2022,
dba slotted rotors.
QFM brake pads
ADR approved braided hoses.
Fat as fuck koyo rad
tuned length mandrel bend headers + mandrel bend exhaust with reverse cone megaphone (all custom made) and headers were ceramic coated then dipped in chrome
has a complete interior and everything is in tact. all you need to do is drop the motor/box in wire it up (all the wiring is there loom and chassis wiring) setup the fuel system and you're on your way. i srsly cbf finishing it its too hot and i dont have the time. all you need to complete this is a gearbox xmember, everything else is there. the shell is in very good nick and only has 2 small az rust spots (smaller than a 5c coin) (and is surface rust only),
10k or swaps for a car worth 7k plus 3k myway
located brisbane. please dont be silly and comment stupid shit... if it doesnt sell ill finish it and sell for 13/14k so save yourself some moolah and take advantage of my laziness ... and no i will defs not separate anything
I am not sure this is what we call "very good cond" or just surface rust.....
