Results 1 to 10 of 14
Thread: Headlights Playing Up. Switch, or Relay?
    Dim
    Menai
    Default Headlights Playing Up. Switch, or Relay?
    Hi Gents, the headlamps started playing up on my AE86 the other day.
    when I flick the knob to headlights on, the headlights don;t come on, however my instrument cluster High Beam indicator is on.
    Pulling the high beam lever works fine, as do the parkers.
    First thought is it's the switch, and perhaps something broken on the inside. But I should I also be considering something else?
    Mt Macedon
    AE86 headlight switches often cause problems. Usually meaning the dash lights don't Work, but I've had one that would only intermittently turn the headlights on.
    You can fix them by pulling them apart and resoldering the connections on the little board inside. Check and clean the contacts for the headlight switch too. Hopefully should get you running Again.
    Dim
    Menai
    Took your advice and also followed the guide in this but still no luck. At a bit of a loss here, all the contact points have been cleaned up and look good, and all the connections have been touched up with a bit of solder. Is there a way I can check the headlights still work by bypassing/bridging the switch?
    Measure with a multimeter power at the headlight itself. If you do a continuity test on the switch it should tell you if it is working as expected.
    Could be as simple as both globes failed on low beam. Had this happen once before, and I was checking everything but the globe itself.
    Dim
    Menai
    Cheers Matt, I'll have a play around with it. I did a continuity test on the switch and that definitely looked good.
    If there's no power at the headlight or the actual globes being out that wouldn't explain the High-Beam indicator coming on would it?
    Dim
    Menai
    I hear the headlight relay click when the witch is turned on, but when I check the voltage at the plug I'm not getting a reading, however when the high beam paddle is pulled I've got 12v from two of the connectors to what I assume is the ground.
    Any suggestions?
    Power to high beam should be considered completely separate from low beam as the globes are twin filament. The high beam indicator is just a globe in the dash to say the high beams are on.
    I'll have a look at how mine works tomorrow and report back with more detailed info on what to check.
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Default headlights
    Sounds like the relay or the power feed connections. Turn the lights on, and check for power at the 10A fuses. Dave W
    Dim
    Menai
    Hi fellas, have not had the chance to look at this since my last post on the weekend. However to add another piece of information when I have the headlight switch set to 'on' and the high beams set to 'off' the high beam indicator bulb is at full brightness, however when I activate the high beams this bulb then dims and is about half as bright.
    I think I'm leaning towards something shorting out in the switch, but will test other hypotheses this weekend.
    Senior Member luke20's Avatar
    Oct 2012
    Luke
    Qld
    Brikdale/Redlands
    The exact same problem happened to my 86. then one day they just started working again lol
  1. Blower Relay and Tail light Relay connections to 4age 20v ECU.
    By paulv in forum Technical - Questions
    Last Post: 9th January 2012, 01:33 AM
  2. light relay switch
    By Julz in forum Cars or Parts Wanted
    Last Post: 13th July 2009, 08:28 PM
  3. AE86 head light switch and wiper switch
    By cando1 in forum Car Parts For Sale
    Last Post: 27th January 2009, 01:02 PM
  4. IGNITION SWITCH AND KILL SWITCH
    By bigpuppa in forum Car Parts For Sale
    Last Post: 29th June 2007, 11:32 AM
  5. head light switch and wiper switch
    By Johnny_08 in forum Cars or Parts Wanted
    Last Post: 5th May 2007, 09:31 PM
