mounted where? Haha
What the hell is mounted there
MOPAR or no car!
mounted where? Haha
That top panel drift kid was talking about. What are the holes from?
MOPAR or no car!
Heaps of crap, vin plate, compliance plate, heater tap, a few spare bolt holes for factory crap
What drift kid said :p
Finally got around to picking up a welder
Started welding up all the holes in the bay, done half of them so far
Havent welded for a few years so some parts are alot rougher than others
Its all getting ground down smooth so it isnt too bad
Welded up the radiator support part too, noticed theres alot of holes along there that arent used
Random huge ones which look like it was from bonnet pins
Welding all of them up & laying some bog over to start fresh
still in early stages
Had to weld some bolts to the under side of the holes to plug the hole, theres probably a cleaner way but it worked fine
Going to cut the excess bolt thread off & grind it down so it isnt noticeable
Really respect professional welders, its definitely harder than it looks!
You need to clamp a thick strip of brass under the metal so you you can pool the steel nicely and fill it without needing to grind the back. Usually you will have the wire poking through on the back and its quite sharp if you don't.
Speeds it up a lot.
thanks for the tip! gotta find some brass now
Brass or copper, even aluminum, any non ferrous metal
Few more goodies arrived
bc rear spring perches
Hks 272/ 264 cams
Got them for an absolute bargain!
