Page 9 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 81 to 90 of 138
Thread: Harry's AE86 Build
  1. #81
    Senior Member 4doors's Avatar
    Jul 2010
    Andy
    goldy
    It's amazing how those little fog lights change the look of the front end. It's much better. Keep up the great work, your efforts will pay off!
  2. #82
    Aug 2014
    Harry
    South Australia
    Barossa
    Thanks i'll look into it
  3. #83
    Aug 2014
    Harry
    South Australia
    Barossa
    Non foglight grill is now foglight grill!
    Wired them up - proper connectors to suit the globes are on the way also
    The wires have been tucked up under the guard & all wrapped in plastic hose
    Modified the cluster surround to fit the switch, blanking plate removed then added the switch with led LED
    Thermos are wired up also, just need to mount switch & wrap the wires in hose
    Have a heap of stuff on the way too
  4. #84
    Aug 2014
    Harry
    South Australia
    Barossa
    It really does!
    Thankyou, much appreciated
  5. #85
    Aug 2014
    Harry
    South Australia
    Barossa
    Happy 86 day!
    Paint stripped & painted the valve covers blue & shaved down the words
    Plenty of clear coat too
    Adjustable trailing arms arrived
    Also a few little bits
    - sq engineering coil pack plugs
    - small radiator overflow bottle
    - bonnet struts to replace the standard bonnet stick
    Pulled the fuel tank out
    still had 1/2 tank of petrol in it :p
    took a while to empty with the fuel pump haha
    Cleaned & painted - filthy
    Works out its a jdm tank!
    Has internal baffles
    Awesome!
    Looking into the fuel side of things
    Plan
    -Bosch 070
    -Surge tank
  6. #86
    Veteran drift kid's Avatar
    Glossodia
    Looking good man, keep it up
    Sent from my D6653 using Tapatalk
  7. #87
    Aug 2014
    Harry
    South Australia
    Barossa
    Thanks man
    Likewise!
  8. #88
    Will
    Nairne
    Keen as to see this finished mate, looking mint!
  9. #89
    Aug 2014
    Harry
    South Australia
    Barossa
    cheers man!
    When its done i'll go for a cruise up your way & you can give it a drive
  10. #90
    Aug 2014
    Harry
    South Australia
    Barossa
    Been busy!
    Pulled the complete rear end out
    exhaust too finally haha (over diff style)
    Driveshaft out to change the uni joints & centre bearings
    Cleaned everything & painted
    Petrol tank too
    whilst the high pressure was out i gave the underneath of the car a solid clean
    (A few days before the engine went i was having some run with a mate in the dirt & grass, good times!)
    Now its all bare i can finally give it all a decent paint underneath!
    Started making the rear hard brake lines up too, aeroflow 3/16 size
    also using a mini tube cutter to make it a clean cut (found this out the hard way, angle grinder + brake line + flaring tool = baad
    never used a flaring tool before so the first few attempts were on old lines
    Easy when you know what to do! Haha
    New oem tail light gaskets arrived
    Over looked this when i first put the whitelines on but since the old adm ones were covered in silicone & started to rust underneath its better to be safe
  1. Harry's F20c AE86
    By Hazza in forum AE86 Owners Forums
    Last Post: 21st April 2012, 01:28 PM
  2. Harry's Diner
    By mikkas in forum General Topics (No Technical Questions)
    Last Post: 3rd February 2008, 10:42 PM
  3. New Harry Potter Movie
    By RB MaNiAc in forum Offtopic Discussions
    Last Post: 18th July 2007, 11:21 PM
