Page 1 of 14 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 139
Thread: Harry's AE86 Build
    Aug 2014
    Harry
    South Australia
    Gawler
    Default Harry's AE86 Build
    Hey fellas!
    Heres my pride & joy
    My 1983 ADM ae86 sprinter
    COMPLETE SPEC LIST
    (UPDATED 11/11/15)
    EXTERIOR
    Orange paint - unknown colour
    black bumpers
    zenki front bumper
    zenki lip
    kouki rear bumper
    rear pods - j blood style
    kouki headlights, indicators & letterbox grill modded to suit fogs
    Kouki fog lights
    whiteline tail lights with jdm number plate lights
    Rx7 fc aero mirrors
    TRD wing
    TRD Window sticker
    Bonnet struts
    INTERIOR
    Gt apex front door cards
    gt apex rear door cards
    adm rear seats
    Bride Stradia seats with bride rails - bottom mount driver & side mount passenger
    hatch cover
    hatch parcel shelf
    Nardi classic steering wheel
    Amp
    alpine speakers
    Sony rear speakers
    JDM whiteline speedo
    jdm speedo chime
    initial d spec cup holder
    TRD Gearstick
    broadway mirror
    WHEELS
    SSR Starshark
    14x6.5+4
    25mm spacer all round
    ENGINE
    4AGE 16v
    rebuilt
    bigport head
    smallport block
    trd 0.8mm metal head gasket
    hks 272 264 cams
    Upgraded valve springs
    adjustable cam gears
    ACL race bearings Throughout
    acl pistons & rings
    Forged rods
    ARP headbolts
    ARP main bolts
    Mrp ladder caps
    ARP rod bolts
    Port & polish
    20v silvertop itbs
    sq engineering 70mm trumpets
    t3 bigport to silvertop adapter
    internal filters
    new sensors
    ECU
    adaptronic E420d with 2m loom
    braided wiring
    FUEL
    Jdm tank
    Walbro 255 in tank fuel pump
    braided lines
    speedflow fittings, -6an
    OIL
    sandwich plate with -10an speedflow fittings
    braided lines
    aeroflow oil cooler
    GEARBOX
    t50
    new gaskets
    ajps shifter rebuild kit
    ARP flywheel bolts
    DIFFERENTIAL
    t series
    tomei 2 way lsd
    IGNITION
    1nz coilpacks
    sq engineering coil pack plate
    sq engineering dizzy blanking plate
    16v smallport dizzy
    bee*r limiter
    apexi turbo timer
    EXHAUST
    powercraft tornado header
    Over diff exhaust shotgun style tips
    STEERING & SUSPENSION
    FRONT
    superpro bushes throughout
    rebuilt steering rack
    new tie rods
    new balljoints
    ajps lock spacer
    ajps rca 40mm
    weld on coilover conversion
    10kg springs
    St185 celica kyb excel g shocks
    cusco camber plates
    Cusco strut brace
    REAR
    Superpo bushes
    6kg ajps springs
    Sierra kyb excel g shocks
    Bc adjustable spring perch
    ajps traction brackets
    ajps panhard rod
    Adjustable trailing arms upper & lower
    strut brace
    BRAKES
    New tucked hard lines
    Bm44 non abs bmc
    -3an speedflow bulkhead fittings
    FRONT
    Rx7 fc calipers
    rebuilt
    Ajps rx7 to ae86 adapter plates
    projectmu pads
    slotted rotors
    braided lines
    new wheel bearings
    REAR
    Ae86 brakes
    rebuilt
    projectmu pads
    braided lines
    ajps rear disc conversion adapter
    slotted rotors
    new wheel bearings
    Bit of a back story..
    I used to own a 2jz soarer which was my first car, bought it dead stock & did a heap of mods. Very clean & had only 128,000kms
    But it was lacking something..
    character.
    It wasn't special, i loved it but i felt i couldnt grow with it, learn new things, meet people & better myself so i had to let her go.
    Here she was in her final form at AJD
    So on a cold winters afternoon i recieved a text about a sprinter for sale locally, it was exactly what i wanted
    So this is where my story begins
    the story of the ae86.
    Aug 2014
    Harry
    South Australia
    Gawler
    This is what she looked like the day i picked her up.
    Goodbye adm grill, hello levin grill!
    4agze bigport afm series 1
    7 rib
    out of a mr2 aw11
    nevo 175mm pulley pushing 12psi with a sc12
    gave the rocker covers a paint, new pod, new trd leads & clear timing belt cover
    Got the mod bug and couldnt resist
    Ssr starshark
    14 x 6.5 + 4
    Whitelines!
    Aug 2014
    Harry
    South Australia
    Gawler
    Drove her through the hills & went hard, it was better than i ever dreamed of
    Then it went bang
    Driving to work one day & it started making unusual noises, didnt think much of it at the time because i thought it might have been a loose wire rubbing or something. One take off from the light & it popped.
    Why hello there conrod!
    I was devastated, assuming after the first oil change there was chunks of metal coming out i highly doubt the engines had an 'easy life'.
    One too many limiter bashes i think.
    So i picked myself up & started searching for a new engine.
    Looked awful when i picked it up, covered in grease & had pink cam covers. Was rather cheap so i didnt mind
    After a lot of degreasing & a lick of paint, TRD oil cap, TRD leads & a carbon fibre spark plug cover this is what it looked like
    This will be the start of the rebuild.
  • #4
    Aug 2014
    Harry
    South Australia
    Gawler
    I bought a t3 cooling panel
    little did i know at the time it only suited trueno so i sold it off
    ordered a set of bride stradias with genuine bride seat rails.
    bee*r limiter
    Apexi turbo timer
    mainly used to read o2 sensor & air fuel ratios
    And a greddy catch can
  • #5
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Very nice bud. If you were walking around at the cfs cruise meet point, you had a brief chat with me while I was moving my car.
    FYI, unless you already have a wide band O2 sensor, I am not too sure you will gain much information from the apexi unit.
    Nice build, looking good mate
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  • #6
    Aug 2014
    Harry
    South Australia
    Gawler
    Thanks man
    Ah yeah i remember!!
    Checked it out at the marion stop :p
    thats what i was thinking too, no wide band
    I had it wired up when it was running & it worked okay
    was interesting to see what it did
    Might use it again later down the track
    Cheers!
  • #7
    Aug 2014
    Harry
    South Australia
    Gawler
    Fast forward a few weeks/ months to now
    Dismantled the new engine bought some adjustable cam gears
    & gave it a paint
    Brides in, Bubble shifter & a nardi
    Bride rear inserts
    (Going to get the rear seats & front door trims done in bride by a professional, attempted myself but didnt go to plan
    Engine out & bumpers, lights etc
    still need to take off the left fender, damn sikaflex stuck to the bottom from the side skirts
    Still need to take a few things out along with this hideous home done loom :/
    Storage is really building up! Eveything bagged & labeled
    zip lock bags are my saviour :p
    Bumper & lights are safe away from harm & damage
    Complete steering rack + cross member out
    Going to be rebuilt
    Gearbox out, so much grease n grime!
    Found out it was a Rx7 brake upgrade!
    Didnt take much notice prior until i looked at it closely
    all wrinkle painted & fresh
    All new bushes
    superpro
    Ajps rca's 40mm
    Pistons look okay but bought new ones + rings for piece of mind
    Staying with stock conrods i reckon, considering aftermarket but see what happens
  • #8
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    This is getting done so beautifully!
    Keep it up man!
    quit hatin get bakin!
  • #9
    Aug 2014
    Harry
    South Australia
    Gawler
    Rip 4agze :'(
    sold off the good bits so to the scrap yard it goes
  • #10
    Aug 2014
    Harry
    South Australia
    Gawler
    Keep it up man!
    thanks man!
    Really appreciate it
  • Page 1 of 14 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    1. Harry's F20c AE86
      By Hazza in forum AE86 Owners Forums
      Last Post: 21st April 2012, 01:28 PM
    2. Harry's Diner
      By mikkas in forum General Topics (No Technical Questions)
      Last Post: 3rd February 2008, 10:42 PM
    3. New Harry Potter Movie
      By RB MaNiAc in forum Offtopic Discussions
      Last Post: 18th July 2007, 11:21 PM
