Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 11 to 20 of 74
Thread: 0036's AE86 Levin Resurection Build
  1. #11
    Nat
    Newcastle
    Not a bad pickup for $2k in my opinion.
    I quite like the old school SAAS seat too, suits the age of the car for sure
  2. #12
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Well my soda blasting guy lost mine so got a new one. Contact Corolla spares as he is cutting an old blue one up you might be able to get that from it
  3. #13
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    TA22 Celica will bolt in, but it's substantially narrower. RA40 the mounts are a little off but it can work and RA60 is wider.
    So double check which Celica diff you're getting, as not all T series are the same.
  4. #14
    Aug 2010
    Geoff
    mt dandenong
    Really common for the seat mount to snap, happends because people "fall" into the seat instead of entering the car normally. You could make up a replacement uprated part easy or take one from a similar car like ke70 at a guess.
    Price on your diff comes down to whats being reco'd and what model of t series it is.
  5. #15
    Member 0036's Avatar
    Mar 2015
    Steve
    ACT
    Belconnen
    Ive messaged the guy about the diff, will let you guys know when i find out, will see if he can get me the seat mount too, because at the moment ive got a really bodged support braket in place bolted to the old mount to stop any further damage
  6. #16
    Mar 2015
    Steve
    ACT
    Belconnen
    Ok just heard back its off a ta22 so should bolt strait in?
  7. #17
    Site Supporter
    Nov 2012
    Tony
    I don't have a good opinion of Corolla spares for a very basic reason.
    i had an ecu for sale for $60 a couple of years ago, he offered me $25 for it. I let it go for $40 and the next day it was up for sale for $130.
    he isn't a mechanic so I doubt he would know how to "rebuild" a diff, what does it include? He pulls cars apart in his dad's backyard, not a licensed wrecker.
    I know everyone does the odd car here and here but hey at least we aren't charging a premium for the parts we sell
  8. #18
    Mar 2013
    Mirko
    You cant really blame him for buying cheap and selling for more man if you took the deal. No one forced you to sell
  9. #19
    Mar 2015
    Steve
    ACT
    Belconnen
    Hey Guys,
    Just an update, so over the last two days ive been doing a major service on the 86, changed diff, box and engine oil aswell as the air and oil filter and flushed the coolant(for the most part). Had a good look at the diff, and after filling it up ive come to the conclusion its just the gasket thats causing the leak, dont know whether ill change it as im looking to get a diff thats not locked for it, but it will do for now so i can drive it around. So after i had done everything i started her up and drove her for the first time, it was glorious! (for all of the 10 meter driveway in first!). Anyhow i started to bleed the coolant and one of the belts snapped, i believe its the A/C compressor belt, not a 100% sure?
    Fortunatly i had already ordered belts from supercheap so hopefully ill get them soon. Anyhow i figured i could go ahead with bleeding the coolant, but noticed alot of oil coming out of the box, it was coming out at a steady rate whilst the engine was idling, anyone have any ideas?
    Is there supposed to be a hole in this bolt? im pretty sure this is where it was coming from? Im not familiar with these cars so i dont know?
    She is back in the shed till i know why its leaking from the box and thats were im at now.
    Also ive decided to bog up the pop-rivit holes in the rear panels and just give it a coat of black paint so it doesnt look so bad for now as i dont have the money to get them cut and re-welded at the moment.
  10. #20
    Aug 2010
    Geoff
    mt dandenong
    Its been a while but the circled bolt is the filler hole and the bolt underneath is the drain hole. There shouldn't be a hole in the top nut. A little further up and towards the bell housing there should be the reverse switch which commonly leaks.
  1. AE86 Levin - Video Build
    By brains in forum AE86 Owners Forums
    Last Post: 28th July 2013, 07:27 PM
  2. My AE86 build.
    By Dskew3 in forum AE86 Owners Forums
    Last Post: 5th March 2013, 11:43 PM
  3. My Jap Ae86 Levin To Paddy Spec Build
    By sc86 in forum AE86 Owners Forums
    Last Post: 22nd June 2012, 07:23 AM
  4. the resurection
    By steroidchickens in forum AE86 Owners Forums
    Last Post: 13th August 2009, 08:47 PM
  5. ke70 build from ae86
    By damo_00 in forum Technical - Questions
    Last Post: 14th May 2008, 03:10 PM
