Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 21 to 30 of 74
Thread: 0036's AE86 Levin Resurection Build
  1. #21
    Member 0036's Avatar
    Mar 2015
    Steve
    ACT
    Belconnen
    Ok, ill have to try and replace the bolt, almost 100% sure it is what was leaking but ill check that too
  • #22
    Mar 2015
    Steve
    ACT
    Belconnen
    Hey Guys another update, seeing as im just waiting for parts at the moment i went to work on removing the fiber glass cover on the left rear quarter panel. I had assumed it had been put on to cover damage like the one on the other side, and that it would have rusted out the metal underneath. However after getting the million pop-rivitis out i found the panel was completely fine! no rust either which is amazing as i have yet to find any real rust on the car.
    (just dirty no rust)
    Makes me wonder why the hell someone would drill holes in a panel to pop rivit a cover onto it? The previous owner has essentially destroyed this panel by drilling holes in it for no reason.
    Im going to clean it up, bog the holes and give her a coat of paint, probaly sometime next week as i have run out of money already this week!
  • #23
    Jun 2013
    Luke
    melbourne
    Any chance you can use a mig and weld the holes up instead of welding them
  • #24
    Mar 2015
    Steve
    ACT
    Belconnen
    Quote Originally Posted by Aussie_XLR View Post
    If you mean instead of bogging them than yes, dont have a mig and i cant personally weld but my dad can so im going to see if he will have a crack at it for me, only have arc at the moment, might have to buy a mig but
  • #25
    Veteran drift kid's Avatar
    Glossodia
    I had to weld up all of my over fender holes not long ago, how big are the holes? I had 9mm holes from the riv nuts and had to cut little 15mm squares out of thin steel to put behind the hole, tack weld on, grind flush and bog smooth, gives it some reinforcement
  • #26
    Aug 2010
    Geoff
    mt dandenong
    Just make sure you dont heat the panel up to much when welding the holes otherwise it'll warp. And paint the inside of the panel after welding or it will rust from the inside.
    Check under the rear window trims for rust, common spot, same goes for the top windscreen channel, better to do it once and properly. Use something like por15,
  • #27
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    get a thick soldering iron and solder them up worth a try!
    AE86 THE BEST
  • #28
    Mar 2015
    Steve
    ACT
    Belconnen
    Quote Originally Posted by FAST EDDIE View Post
    Thats not a bad idea actually ill have a look into that
  • #29
    Glossodia
    Quote Originally Posted by dove grey 64 View Post
    Great advice
  • #30
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Solder or braze it . You will need a good flux in the solder proccess . File the repair area , then etch prime it before undercoating . Also make sure you etch prime the other side to seal it so it does not rust later . You will need to remove rear interior panels , but worth the effort . Some early TOYOTA's do not even have undercoat behind the interior panels . A T18 I did some months ago had areas of raw steel , no rust proofing or undercoat , covered in surface rust . So worth a look if the car is a keeper .
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
  • Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
    1. AE86 Levin - Video Build
      By brains in forum AE86 Owners Forums
      Last Post: 28th July 2013, 07:27 PM
    2. My AE86 build.
      By Dskew3 in forum AE86 Owners Forums
      Last Post: 5th March 2013, 11:43 PM
    3. My Jap Ae86 Levin To Paddy Spec Build
      By sc86 in forum AE86 Owners Forums
      Last Post: 22nd June 2012, 07:23 AM
    4. the resurection
      By steroidchickens in forum AE86 Owners Forums
      Last Post: 13th August 2009, 08:47 PM
    5. ke70 build from ae86
      By damo_00 in forum Technical - Questions
      Last Post: 14th May 2008, 03:10 PM
