Results 1 to 2 of 2
Thread: newbie
    Mar 2015
    josh
    Keith
    Default newbie
    hi all, obviously im new to the page, i have a ke30 corolla which i'm doing an ecotec conversion with, pretty much want to milk someones brain that has done it just to help out with the process. i've got engine mounts sorted out i just need help with the gearbox mount and wiring, the rest looks reasonably straight forward to work out. i really want pictures of the gearbox mount for a t5 if anyone has done it. thanks in advance if anyone can help out.
    Depending the model ecotec you will need the security deleted or run an aftermarket ecu. The gearbox mount you should be able to adapt the stock t5 mount onto a custom xmember. It isn't uncommon to need spacers when installing a larger box.
    Best bet is to get under it , have the engine level and see what needs to be done
  • Similar Threads
    1. NEWBIE
      By mikeygtv in forum General Topics (No Technical Questions)
      Last Post: 22nd January 2013, 08:12 AM
    2. Newbie Here
      By KeshiNoMi in forum General Topics (No Technical Questions)
      Last Post: 21st July 2011, 03:34 PM
    3. Hello. Newbie here
      By wolf45 in forum General Topics (No Technical Questions)
      Last Post: 9th July 2011, 11:40 AM
    4. Newbie with a newbie question
      By DjB in forum General Topics (No Technical Questions)
      Last Post: 22nd May 2007, 12:33 AM
