Have lost patience with my 4kc not starting so i'll give someone $50 to get it running.
PM me if interested. Located NOR as well
exactly! it's a 4k, hit it with a hammer, it'll start fist time 2% of the time, is it cranking at all? have you checked for spark? slow to crank?
fuel pump or blocked fuel filter
its a 4k
if its cranking and its not going you must be turning the key wrong or something
HAHAH I LOVE BOOST LOOSING!!
alternator?? need a better diagnosis, Dr Spoontah
Sorry i took so long to reply but i don't have computer access at the moment.
-Bought a running engine with even comp accoss all 4
-tried to start it once in the bay and wired up but wont start
-checked fuel filter and lines, and it pumps out so no blockages
-battery was a bit flat so it i hooked it up to running car for a while to give it some life (tiny battery only has 300cca's though). . . . . still wont start
-checked for spark and it seemed weak so put new leads and plugs in . . . . . won't start
-swapped old dizzy in as i knew it worked on old engine . . . . . won't start
-checked timing about 5 times over and was right . . . . guess what, still won't start
Thinking i need a new battery with more CCA's
are you sure its firing on the right cylinder at the right time?
does it crank nicely or more of a chug and cough and fart?
and is there fuel actually coming out the throat of the carby? you can still have fuel to the carby but not come out the carby
what condition is the coil in?
have you tried a start-ya-bastard start
spray start ya bastard down the carby throat and try start it, if it runs but only for a few second you have fuel problem
what suburb you in?
Yeah its firing on one at the right time.
Cranked nicely until the battery went flat.
No fuel comes out the carby, but isn't the electrical connection on the carby related to fuel because if you disconnect it while the car is running it shuts off?
Coil is in good condition
Haven't tried carby cleaner yet
Located in Ellenbrook
