Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: The Pointless tale of a guy and his sprinter
  1. #11
    Member azbro's Avatar
    Mar 2012
    Aaron
    South Australia
    Chandlers Hill
    Eventually I got some slightly better wheels, key word slightly.
  • #12
    Mar 2012
    Aaron
    South Australia
    Chandlers Hill
    July 2012: long awaited handling upgrade
    Yes it was finally time for some upgrade parts, on the shopping list:
    - Jap lsd disk brake rear end
    - front and rear swaybars
    - adjustable panhard rod.
    Sway bars and panhard rod: For these parts I contacted AJPS, my mate had a whiteline panhard but I wasn't much of a fan of how it had to be removed to be adjusted where as AJPS offered a product that would allow it to be done on car. As for swaybars Dave recommended I went for only a mild increase in size, I cant remember what size it was now but they worked well.
    JDM diff: I managed to source this locally from a Japanese parts wrecker, it cost me $950 for a complete setup, it did however need some maintenance, after pulling it apart and checking everything over, rebuilding the brake calipers, getting the disks machined, and putting new bearings and seals in I was about another $150 out of pocket so $1100 all up which I was still fairly happy about.
    Update: The diff is noisy af!
  • #13
    Mar 2012
    Aaron
    South Australia
    Chandlers Hill
    Sep 2012: Another mistake
ID:	36858Click image for larger version.
    Well once again I made a mistake and the result was a slight tap with a guard rail (not the good kind of tap!)
    I was driving on a route I know very well was actually going pretty good until I came up to a corner with more pace then normal, normally I'd down change but it didn't feel like I needed to this time, I decided to change gear and it resulted in some compression lock and a wriggle along the rail.
    I replaced the front guard and parker and put a few cable ties around the broken grill clips.
    After this I began to learn heel-toe and abit better driving techniques and im actually happy this happened.
  • #14
    Mar 2012
    Aaron
    South Australia
    Chandlers Hill
    In October 2012 my rego ran out and I decided to take the car off the road for a refresh over summer... little did I know
    Heres some pics of it in the months leading up to October.
ID:	36860Click image for larger version.
ID:	36861Click image for larger version.
  • Page 2 of 2 FirstFirst 1 2
    1. WTB a ae71 clutch line,tale shaft and radiator
      By aaronke70 in forum Cars or Parts Wanted
      Last Post: 12th January 2011, 01:09 AM
    2. tell tale signs of ae86 struts
      Last Post: 25th November 2010, 10:07 AM
    3. Who is the guy with the sprinter in bagdad?
      By Skid_KE70 in forum Hobart & TAS Events and Discussion
      Last Post: 2nd November 2009, 11:19 AM
