I'll allow it if you can handle all the lowball offers you'll get
Sent from my iPhone using Tapatalk
Hey guys, keep in mind this isn't a sale. I'm looking to know what it would be worth to someone. Mods if this isn't cool, please delete.
-83 JDM Trueno Coupe
-Located Townsville, QLD
-124xxx on dash, About 6000 on engine
-4 months QLD rego
-Blacktop 20v, 143hp
-Good T50, disc T series, good 4:3's, mechanical locker
Exterior
-One Small area of rust on front quarter panel, paint is average, body is straight
-Fibre glass skirts
-Kouki bars
-ClimAir rain visors
-Full set 15x7.5 Long champs with 90% R888
-Full set 14x7 Watanabes with 95% RE001
Suspension
-Reconditioned manual rack and new bushes
-Power steering knuckles
-GAB strut brace
-Front GAB fully adjustable 8kg coilovers
-Rear GAB damper adjst shocks, 6kg springs, adjustable platforms
-TRD sway bars
-Rose jointed LCA's
-RCA's
-Camber tops
-Prothane bushes
-Rose jointed panhard rod
-Welded rear strut brace
-Rear body brace
-Traction brackets
-Body seam welded
Brakes
-Braided brake lines
-RDA slotted rotors
-QFM pads
-Rebuilt JDM calipers
-Resealed booster
-Resleeved master cylinder
-Cusco master cylinder stopper
Engine
-Dual ECU controlled thermos
-King bearings
-ARP rod bolts
-Spool rods
-CP 12:1 pistons
-ARP head studs
-Kelford 194-C 284/278 cams
-Kelford valve springs
-T3 adjustable 16v exhaust cam gear
-Head reconditioned with clean up of ports and bowls
-60mm SamQ stacks
-Unifilter filters
-RSR modified 16v 4-1 extractors
-No cat, HKS HiPower cat back
-SamQ RWD conversion parts
-Adaptronic E420C, COP's and Kaizen garage loom
-Earls oil filter plate and 13 bar oil cooler
-Exedy heavy duty clutch and pressure plate
-New water pump, radiator, tensioners and all seals
-Starter and alternator rebuilt
Interior
-Seam welded
-Mod plated two seater
-New carpet
-Autometer oil pres, oil temp, water temp gauges
-Nardi deep corn
-Good dash
-Painted black inside
-Velo GP90 on custom rail
-Velo 4 point harness
-JDM door cards, centre console
-5 point Safety 21 bolt in cage
-Average stereo setup
It's a complete, quick and fun package.
Might have missed a few things, read through my build thread for more info and pics, thanks.
Yeah, to be expected.
Well considering you just asking what its worth to someone and not saying its actually up for sale, im moving the thread. I'd have deleted it but it's the best laid out "sale" thread I've seen in a while and would be a shame to delete the worthy effort.
We have a rule of no eoi's in sales threads, cant break the rules
To easy, thanks.
impressive specs, in parts/build i'd say 16-18k, sale as a complete car probably 12-14k
Hey Dan,
Sent you a PM.
is that the original colour? (check the build plate)
Nah, it's been sprayed somewhere in the past and I resprayed the rear quarters after fixing the rear flares. It's originally white over black panda, 2N2.
