Results 1 to 8 of 8
Thread: Question about 1UZFE - 5th Gear, low RPM
    Senior Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Question about 1UZFE - 5th Gear, low RPM
    Hellos,
    I was browsing through the forums and i came across this [. Below is a post by Billzilla...
    So my question is; How is it possible that the car can be driven at about 800rpm in fifth gear without shaking or stalling? coz that's almost no different from "idling in while in gear".
    thanks,
    Max.
    Mar 2011
    Ali
    Auto?
    If it's manual, close ratio W57\58 1:0.86 fifth gear with 5.something:1 rear end.
    Or slipping clutch?
    Veteran Konakid's Avatar
    Henry
    Eastern
    they are just a very flexible motor with a lot of torque and low weight chassis.
    RT142 Estate.
    AJPS.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Does this mean that at 800 rpm in 5th, the engine is still making enough power to move the low weight car without stress? would it struggle if the car was heavier?
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    my brother has a manual vy ss, yes you can get the revs that low and still accelerate cleanly with no shake in 6th IF you are gentle with the throttle. Mash the peddle and the whole car vibrates until the revs pick up over about 1200.
    I would imagine in a car that weighs less than half like a v8 rolla it would be barely noticeable.
    West
    In LS1 Utes you can usually put it into 6th and cruise as low as 1000rpm on the highway dependant on speed and final drive.
    Torque is great and something that 4a owners have only read about in books. The reason i chose 2azfe is it makes more torque than a 4age at peak torque... at 1000RPM.
    Moderator Frak's Avatar
    Jamie
    Which is why I went 4AGTE, more power, more torque and pulls hard to over 8000rpm and with the 6 speed sequential box(with clutch less flat shift), it's never off the boil
    Hachiroku since 1994
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    fuckin mint
  1. Surge @ Low RPM.
    By 4agejet in forum Technical - Questions
    Last Post: 4th March 2011, 10:06 AM
  2. Low RPM minor Surge problem..
    By 4agejet in forum Melbourne & Vic Events and Discussion
    Last Post: 22nd February 2011, 07:17 PM
  3. 4age splatter at low rpm
    By ae13b in forum Technical - Questions
    Last Post: 10th February 2011, 11:23 PM
  4. Idle & Low rpm miss fire - Bigport
    By FUTO_GT in forum Technical - Questions
    Last Post: 13th August 2009, 01:54 PM
  5. 4agze Problem at low rpm boost
    By DavisJD in forum Technical - Questions
    Last Post: 22nd March 2006, 09:43 PM
