Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 48
Thread: AE92>ADM86 wiring questions
  1. #21
    Aug 2012
    Braden
    Bendihoe
    Okay so finally got a bit of time during the day and have depinned the two ECU plugs, the body loom plug, two square black plugs and the ignitor plug. It was driving me insane as to how messy it was.
    Right now i'm playing ID the plug, I'm going to document every plug and save it in a thread for everyones use as there isn't a thread out there that has smallport plug list (That i've been able to find)
    Air conditioner Compressor
    Coil
    Oil pressure for cluster
    Thermo fan control switch
    Air conditioner pressure switch
    Reverse Light Switch (AE92 FWD Box)
    Dizzy
    Knock sensor
    Air intake temp
  2. #22
    Labelled some of them for you. Don't take these connectors out of the loom as it'd be a nightmare to put them back in.
    I might be wiring a ke70 over the weekend so I'll grab some pictures for you to make it easier
  3. #23
    Mt Macedon
    Concur with above labels. I'm pretty sure the one marked Dizzy or AC is the Dizzy.
  4. #24
    The unlabelled one is most likely reverse lights. But I'm unsure
  5. #25
    Aug 2012
    Braden
    Bendihoe
    Starting to get some good progress done. The injector loom is all taped up and ready for plastic shielding, just finished the MAP/throttle body loom. Now moving towards the second water outlet sensor & intake sensor.
    in this loom there is the intake mani sensor, the brown water outlet sensor and the starter plug. Question, the original 4ac starter plug is the same and is in the 4ac body loom. Should I use the 4age one or the 4ac one
  6. #26
    Aug 2012
    Braden
    Bendihoe
    Are these two plugs for the Ae92 fuse box?
  7. #27
    You can use either, but if you retain the original 4ac starter wiring there will be no need to modify anything to get the starter to work, however you will need to tap into the ae92 wiring to signal the ecu the car is trying to start.
  8. #28
    Those black plugs i believe 1 to be for the fuse box and the other for the cabin loom to pick up the ignition power and starting power etc.
    They won't be required in the ae86 loom.
  9. #29
    Aug 2012
    Braden
    Bendihoe
    Awesome Matt. I'll adapt all the 5 & 6 pin plug wires and hide them within the loom sections. As for the starter. If the starter gets power through the body loom I'll utilise the 4ac one then. Makes most sense.
    Who are these little suckers, they're connected to the injector loom.
    Radio Suppressant Connection ( Stops that whistle thru the stereo when u rev the car)
  10. #30
    Aug 2012
    Braden
    Bendihoe
    This sucker too, what is he
    (Pretty sure the charcoal canister purge)
  1. AE92>ADM86 Intake manifold questions
    By Bray in forum Technical - Questions
    Last Post: 4th May 2015, 11:23 PM
  2. Wiring Questions on 20v conversion
    By tan18d in forum Technical - Questions
    Last Post: 10th September 2014, 07:49 AM
  3. Plugs Off Ae92 - Smallport Wiring Loom
    By Matt in forum Cars or Parts Wanted
    Last Post: 8th March 2011, 11:10 AM
  4. 4AGE idle and wiring questions!
    By shortround in forum Technical - Questions
    Last Post: 28th November 2009, 09:02 PM
  5. (SA) AE92 Levin GT-Z
    By 4aboostin in forum Cars for Sale (Toyota Only)
    Last Post: 28th January 2009, 06:47 PM
