I have decided to overhaul my engine completely, which was running fantastic. When I dismounted the crankshaft and main bearing, I didn't see if its std or oversize because it only said some numbers and letters. I have taken a picture to help with the problem. The order from the picture from left to right: #1 rod, #5 main, #4 main, #3 main, #2 main and #1 main. Is it ok to just put some std main and rods bearings? Thanksss..
You need to actually measure the crank journals to see what size you need.
Sent from my iPhone using Tapatalk
