Results 1 to 4 of 4
Thread: Fuel Pressure Test Kit for 4AGE
    Aug 2011
    George
    Sutherland Shire
    Default Fuel Pressure Test Kit for 4AGE
    Hi there,
    Does anyone know where I can buy a FP (Pump & FPR) test kit that includes a ring / union fitting for OEM fuel rail; or failing that a ring fitting that I can buy for use with a cheap Ebay kit?
    Toyota have an SST < 09268-45011 > but I just know it's going to be bloody expensive.
    It is one thing to test the pressure, but ideally if you are going to spend money you want something that will also measure the flow as pressure tests alone aren't enough to rule out fuel as being a problem.
    Any hydraulic place would be able to sort you out with an adapter from banjo bolt to something with a barb on it to accept the EFI hose of the tester.
    Aug 2011
    George
    Sutherland Shire
    Thanks for that; but I just want to confirm fuel pressure to input into ECU tuning program.
    Have have ordered a kit off eBay kit & will p/u a Banjo fitting this w/e.
    What kit did you end up buying?
  1. Stock 4AGE Fuel Pressure Regulator
    By timbo in forum Cars or Parts Wanted
    Last Post: 23rd August 2011, 12:29 PM
  2. 4AGE 20V BT Fuel Pressure Reg.
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 29th September 2010, 08:53 AM
  3. Replies: 6
    Last Post: 29th May 2010, 10:36 AM
  4. Standard 4age Fuel Pressure Reg
    By Daim in forum Technical - Questions
    Last Post: 6th March 2008, 08:26 AM
