Results 1 to 4 of 4
Thread: Aftermarket ECU - HKS FCON V-PRO
    Ken
    Spearwood
    Default Aftermarket ECU - HKS FCON V-PRO
    Have a full programmable aftermarket ECU for sale that I was going to use on my car awhile ago.
    HKS FCON V-PRO
    Comes with harness for direct connection to a AE86 with 4AG.
    $1100ono - DON'T WASTE MY TIME WITH LOW BALL OFFERS OR STUPID QUESTIONS, I WON'T REPLY.
    The HKS F-CON V Pro is a fully featured standalone engine management system that connects as easily as a "piggy-back" fuel and timing controller. As modifications to a vehicle are made, the need for fuel and timing adjustments becomes critical for performance and safety. The F-CON V Pro with its 32x32 resolution for both fuel and timing maps is the optimal solution. The F-CON V Pro can control up to eight injectors and D Jetro or L Jetro setups. --- Injectors can be set to fire as batch, sequentially or staged. The F-CON V Pro can also read drive by wire vehicles. Programming is done via the HKS Power Writer software; which only Certified HKS Pro Dealers have access to. The HKS Power Writer software for the F-CON V Pro has some very unique abilities to simplify setup and tuning. Via the vehicle start up menus most Japanese import cars can be easily started by selecting the vehicle’s parameters (Make, Model, Engine and etc). Tuning is simplified due to the A/F Feedback control; where a target A/F value can be input and the F-CON V Pro will adjust fuel automatically. Also full data logging capabilities are built into the F-Con V Pro Power Writer software. All major vehicle conditions including; speed, rpm, water temperature, intake temperature, timing, boost, injector duty cycle and etc can be logged to an HKS Pro Dealer’s computer.
    Ken
    Spearwood
    up it goes
    Veteran Dom86's Avatar
    Dom
    Balga
    Can I get one in PInK??
    The Track Car Build: Indigo
    A Heap Of For Sale: The Heap
    Ken
    Spearwood
    Go adjust your skirt
  1. Which Aftermarket ECU?
    By JDM-086 in forum Technical - Questions
    Last Post: 11th April 2014, 09:54 PM
  2. Fully modified 4AGE with transmition and HKS F-CON V Pro ECU swap
    By nikolas4g63 in forum Car Parts For Sale
    Last Post: 16th August 2010, 06:28 AM
  3. aftermarket ecu
    By drftr86 in forum Technical - Questions
    Last Post: 24th March 2008, 12:43 PM
  4. AFTERMARKET ECU
    By drif86s in forum Cars or Parts Wanted
    Last Post: 10th March 2007, 11:10 PM
