Results 1 to 2 of 2
Thread: [PERTH] F series input flange 60x60 bolt spacing, 10mm bolt holes, 102mm dia, 23? splines.
    Aug 2010
    Gene
    Default [PERTH] F series input flange 60x60 bolt spacing, 10mm bolt holes, 102mm dia, 23? splines.
    Hi, I have a 7.5" F series diff & want to put in a stronger tailshaft - Hilux G series sized. I'm after a new companion flange with the bigger diameter and pcd that still fits on the small F series pinion spline.
    These came on the 4runner and surf front IRS diffs as well as on the rear diffs of some F series equipped tarago, hiace and liteace, etc.
    So if you have an old blown diff you don't mind separating the flange from or you've removed a large flange from a diff to put a small one on for a ke70 or ae86, etc. Then let me know.
    Eddie
    Hey mate. Just so you know, you can also get these out of the centre bearing flanges from many many toyotas eg cressida, supra, crown etc. useful that they come from both auto and manuals. You need to machine off 3-5mm off the spline end if I remember correctly. Just line it up with the old one and it's obvious.
    Sent from my iPhone using Tapatalk
  1. [vic] 4x114.3 +10mm bolt on spacers so my shit will fit FARK
    By rthy in forum Cars or Parts Wanted
    Last Post: 3rd March 2013, 01:22 AM
  2. 4age waterpump pulleys - Bolt Spacing
    By LittleRedSpirit in forum Technical - Questions
    Last Post: 24th January 2010, 06:28 PM
  3. 4ac carb bolt spacing
    By shakes in forum Technical - Questions
    Last Post: 24th March 2008, 02:35 PM
  4. AE101 Booster 2-bolt flange [Bris]
    By The Last Streetfighter in forum Car Parts For Sale
    Last Post: 14th March 2007, 12:08 PM
  5. steering knuckle arm bolt spacing
    By drifter7 in forum Technical - Questions
    Last Post: 19th October 2006, 02:26 PM
