Results 1 to 1 of 1
Thread: VIDEO: Learn how to change your brake fluid with Bendix
    Veteran motorculture's Avatar
    Sep 2009
    Sydney, Australia
    Default VIDEO: Learn how to change your brake fluid with Bendix
    Brake fluid by nature absorbs moisture from the atmosphere through microscopic pores in braking lines, and through the small vent in the master cylinder reservoir. As brake fluid absorbs water the boiling point is reduced significantly, in just 12 months most brake fluid will have absorbed approximately 2% water, reducing its boiling point by 75 degrees’.
    The amount of moisture absorbed by your brake fluid can be detected using a brake fluid tester. A sample of fluid is boiled to determine if the boiling point has dropped below manufacturer specifications, indicating high levels of moisture in the fluid.
    Testers that use a conductivity measurement to produce a theoretical boiling point are not considered accurate as each tester is not calibrated to the manufacturer’s product it is being used on.
    If a brake fluid test indicates your fluid is no longer within the specified operating requirements, a brake fluid change must be performed to ensure your vehicles brakes do not fail under heavy loads.
    Once the fluid has been change, it is important to bleed the system, removing any air bubbles trapped in the line which may cause a spongy brake pedal and in extreme cases brake failure.
    Check out this video to learn more about changing your brake fluid.
    For more information about Bendix products and braking systems visit:
    www.bendix.com.au
    www.facebook.com/bendixworkshop
  1. VIDEO: How To Test Your Brake Fluid Correctly
    Last Post: 14th August 2015, 06:06 PM
  2. VIDEO: How to use the FREE Bendix Brake Pad Identifier App
    Last Post: 20th May 2014, 02:15 PM
  3. Bendix Brake Fluid
    Last Post: 1st June 2013, 01:51 AM
  4. Bendix Covers Brake Fluid Functions
    Last Post: 5th September 2012, 01:48 PM
  5. Bendix High Performance Dot 3 and Dot 4 Brake Fluid
    Last Post: 27th October 2011, 11:07 AM
