hey mate, got a pic?
pair ae86 trueno headlight kito lamps (the lamp it self, not the whole unit), some rust around the corners $40
Pair s series axles - surface rust from storage, otherwise ok $20
4A sump, removed from a motor (4ac or 4age) $10
KE70/AE71 Fuel and brake rails, used, seems ok $50
AE86 Trueno driver side front bumper support, fair condition, lower mount to rail has been modified but will bolt in $50
AE86 adm cluster, 303,187kms, good condition except for crack on the lower left of the cluster $40
AE86 adm cluster, 436,474kms, good condition $40
AE71/T50 adm speedo, was removed from running car (at the time) $50
MA/RA60/65 rear hatch wing/cover thing, sitting undercover for a number of years, looks in good shape $50
AE86 Driver side door - bare, some rust lower part of the door, crappy paint and scratches from heavy grit sanding paper - $40
AE86 Passenger side door – light blue, has bump strip, door handles, lock mechanism, light rust on the under side
AE86 Rear Hatch – red, rust on left side and some under parts, no glass, wiper or motor - $20
AE86 Rear Hatch glass – glass only with rubber mould, needs a clean - $50
AE86 4AC full stock exhaust, surface rust - $50
AE86 4AC aircon setup, missing compressor and condenser has some damage - $50
AE86 4AC ADM stock front suspension - swaybar, caster, lca, steering arms, steering rack, front struts (hubs are miss matched ke70, used to roll shell) $150 - may split
pick up altona or tulla area
can ship via ego or what ever
make an offer otherwise will check em on ebay
7AFE block, with std pistons/rods/crank and sump, 150ks when removed, 4age bigport head with cams, adj cam gears - on hold
Pair ae86 trueno kouki fender indicators - excellent condition sold
MA/RA60/65 headlight garnish, sitting undercover for a number of years, looks in good shape sold
SAAS 4spoke wheel with short Toyota bosskit, plastic bump pad and horn. Suit KE70/AE71 can fit ae86 (or simiar toyota's), pretty good condition and rare 80's design. sold
AE86/T50 adm speedo, was removed for running car (at the time) sold
ADM ae86 front engine crossmemeber with steering rack, lca, tierods, knuckle arms, caster rods and swaybar. removed from high kms ae86 - sold
4AGE USDM DIZZY, 4/1 spline with 4pin out (2 grey plugs), used condition - sold
4AGE JDM DIZZY with ADM yellow plug 3pin, 24/4 spline, used condition - sold
4AGE JDM Coil and ignitor, square green plug, used condition sold
4AGE ADM Coil and ignitor, round green plug, used condition sold
4A oil cooler setup (mostlikely 4age ae82), comes with filter sandwich plate, sump with factory return line and ae82 oil cooler (no hoses) sold
Pair ae86 kouki door mirrors - OK condition, looms have been cut, painted in gloss sold
Whole ae86 trueno body and 4age engine bay wiring loom - removed from jdm car, comes with trueno headlight switch and relay - sold
uploaded
pretty much new, no loom
bump
pm'ed
pm sent re dizzy
bump
bump some stuff on ebay
Hey have you got any 4age air conditioning parts? Compressor, lines, etc? Looking for the lot. Thanks
pretty sure got most or complete 4a-c gear, pretty sure they are the same except for the compressor pulley/wheel?
