Results 1 to 10 of 11
Thread: The nuts and bolts of it - surface rust removal from nuts and bolts
    Senior Member jamiesbrain's Avatar
    May 2014
    Jamie
    Default The nuts and bolts of it - surface rust removal from nuts and bolts
    Cleaning up different bits in the engine bay and have a few nut heads and bolts that have surface rust.
    I don't see the point in buying new ones when the existing can be cleaned up to look as new.
    Looking to see who has what tips on cleaning them up (with what) and keeping them rust free.
    Been you tubing it and found some stuff where people are using apple cider vinegar which looks to get rid of the rust which it does well.
    The issue that has many solutions (not sure which are long lasting and not) is coating post rust removal to prevent further surface rust and keep them in good condition.
    Thoughts, ideas etc?
    Some have used WD40 and the like, others clear coat or two and some just paint them.
    I want to keep the metal finish and not so much keen on painting a colour.
    Mt Macedon
    Many years ago a friend had a bunch of parts electroplated. They came back looking brand spanking new with the "factory" yellowish coating.
    I'm not 100% sure what the process was or what it cost, but if you want total factory/showcar finish it may be worth looking into.
    Veteran McLEVIN's Avatar
    Nov 2010
    Zinc plating....its what the irish lads are doing when they are restoring their cars back to factory
    MOPAR or no car!
    Member smackdown.exe's Avatar
    Dec 2011
    J-D
    Gold Coast
    Aus
    Ive had great luck with putting bolts in the sink covered in coke and vinegar or pepsi and vinegar mix 50/50 over night. Have cleaned up some pretty bad bolts, And come up looking perfect with a very fine brush when taken out of the mix
    also a great at unsticking stuck nuts
    Dec 2011
    J-D
    Gold Coast
    Aus
    Also to prevent i then reinstall and spray some crc5.56 on a rag and wipe over the head or wherever i dont want to rust. Haven't had a problem yet
    Wire wheel to clean up and then clear it or plate it. Plating is expensive though
    Eddie
    The other option is to ceramic coat them. Not cheap to do but they turn out mint and will last ages. Coating is also only microns thick so doesn't interfere with thread engagement.
    Sent from my iPhone using Tapatalk
    May 2014
    Jamie
    Thanks guys,
    I had looked at the Ceramic coating side but might also look at the electro and zinc options.
    This gives me some more direction to look into a few options and costs.
    Cheers!
    May 2014
    Jamie
    Can I add it is also that moment you are cleaning up your engine bay and think, what if I just pull the engine out and do a proper tidy up, but then maybe I should clean up some of the engine bay paint....hmmm if I am doing that maybe get the old girl rubbed back and respray...hell ground up rebuild. haha sanity prevailed and I am back to just doing nuts, bolts and screws for the minute.
    Veteran johl's Avatar
    Johl
    haha that is how it usually starts and before you know it your car has been in pieces for 3 years
  1. Wheel Nuts & Bolts
    By evil86 in forum Technical - Questions
    Last Post: 14th September 2010, 04:45 AM
  2. electroplating car nuts & bolts
    By Tally in forum Technical - Questions
    Last Post: 30th April 2010, 05:26 PM
  3. Odd bits - Screws, Brackets, nuts, bolts etc
    By starni_boy in forum Cars or Parts Wanted
    Last Post: 22nd November 2009, 10:58 AM
  4. Shock insert lock nuts and brake caliper bolts
    By Insane in forum Cars or Parts Wanted
    Last Post: 9th June 2008, 07:29 PM
