Results 1 to 3 of 3
Thread: BEAMS blacktop limp mode
    Member Philbo's Avatar
    Phil
    NT
    Darwin
    Default BEAMS blacktop limp mode
    Hey guys,
    I've fitted a BEAMS blacktop to my dad's SR40 Spacia and have one final problem remaining in that it seems to be in limp mode. Everything works except it won't rev past 3000rpm. Sounds like a fuel/ignition cut, bouncing rpm steadily. Just wondering what conditions will induce limp mode?
    Thanks in advance
    - Phil
    Quote Originally Posted by Tim.duncan View Post
    Will you post #4 piston and the centre bearing from the turbo to broom?
    Could be a number of things, best way to determine is to do a diag check. Pretty sure you can wire in an odb2 plug
    Phil
    NT
    Darwin
    Thanks Matt, when I say everything works, I haven't wired the obd plug/check engine light yet Figured it'd just be full of module communication faults.
    Just found this for anyone in the same situation -
    Looks like "fail safe mode" only relates to throttle faults?
  1. BEAMS with Blacktop ITBs on standard ECU?
    By Powerbite in forum Technical - Questions
    Last Post: 27th August 2013, 10:27 PM
  2. Wanted : 3sge blacktop beams head
    By Tim.duncan in forum Cars or Parts Wanted
    Last Post: 22nd October 2011, 04:26 PM
  3. 3sge beams blacktop extractors
    By 4A-G3 in forum Cars or Parts Wanted
    Last Post: 24th January 2011, 08:58 PM
  4. LIMP MODE
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 24th May 2008, 12:29 AM
  5. "LIMP MODE"
    Last Post: 27th March 2008, 11:57 PM
