Results 1 to 3 of 3
Thread: KE70 Conversion Wiring
    Jul 2015
    Zac
    Default KE70 Conversion Wiring
    Hey everyone,
    I am currently stripping out a KE70 for a bit of a track hack. I'm putting in a 4age in and I was wondering what everyone's opinions about fully rewiring everything. I have a full, uncut engine loom and I'm going to have to go with aftermarket gauges and I'm gonna use a beefier fuel pump/surge tank setup.
    I figure I'll probably leave the wiring for lights/wipers etc, though I do plan on using a custom switch panel, any suggestions on what I should and shouldn't leave in there?
    Also does anyone have any links to guides or any build threads that go into detail about the wiring they've used, doesn't have to be specifically KE70 related just anything to give me ideas will be helpful.
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    First, you need to label all of your electrical connectors form the engine bay donor engine harness. This is an especially important if you cannot find enough time tocomplete the wiring of a sub-system in a single day or afternoon. Because you will waste a lot of time if you have to come back a week later and have tore-trace each wire or determine the necessary color codes or wires tocompleting the sub-system circuit.
    I strongly suggest that you spend the time to make a vehicle schematic with each wire’s color codedcalled out on the schematic to assist in the construction of a new wiring harness. Drawing a complete wiring schematic will save more time, then it takesto make it, Vs trying to figure out which wires are which after having been away from the build for a week or two. I made my wiring diagram by enlarging copies of the Toyota wiring schematic from a work shop manual. I then cutting out the ECU and other circuit sections and pasted themon to a 20” x 30” sheet. Then draw in the connecting wires with color codes indicated on the schematic. [Draw it in pencil]use the same wire colorcodes and wire gauges from the Toyota. Using the Toyota stock color codesmake the designing, drawing, and fabrication of the wiring a lot easier.
    Using the same color codes as Toyota will make the installation and trouble shooting of the various sub-system plus any additional electrical components a lot easier to figure out.
    Using the Toyota engine bay harness with all the ECU multi-plugs is the safest and easiest way to go.
    You can never have too many electrical grounds for the main electrical components and accessories. Tap directly into the chassis tubes for your ground wires.
    I would also add a few spare wires in the harness run and note the color code and gauge of the extra wires in the harness, for reference when needed at a later date for possible use for a fan or fuel pump relay. Another option is to just keep some of the un-used wires in the harness and note the color code in your log book.
    You will also want to get the larger grommet for the fire wall, that the ECU plugs will pass through.
    After you have completed the wiring, you need to check each completed circuit. Once you have verified that the circuit is OK, then move on to the next. Dave W
    I've done one before like that, it is a massive job.
    Draw up a wiring diagram, use original earth points and do 1 circuit at a time. I didn't use original colours as it is impossible to buy all the different colours. However, make sure you implement a scheme that works for you. For example constant power is red, accessories is is yellow , earths are black etc. switched relay power green. Then use a diff colour for brakes, indicators / reverse lights.
    Ensure you can separate / disconnect bits of the loom. I bought narva plugs on mine because they are readily available and easy to replace.
    Also keep your relays in the same spot and label what is what. To a point mimick the original loom when deciding to put in a relay
  1. Wiring Questions on 20v conversion
    By tan18d in forum Technical - Questions
    Last Post: 10th September 2014, 07:49 AM
  2. How To: 4AGE conversion into ke70 wiring
    By Brendan in forum Technical - Questions
    Last Post: 2nd March 2009, 10:58 PM
  3. 4age conversion wiring
    Last Post: 17th February 2009, 01:58 PM
  4. Wiring an alternator on a KE70 to 4age conversion.
    By tetsujin in forum Technical - Questions
    Last Post: 29th August 2008, 01:03 PM
  5. Replies: 4
    Last Post: 29th March 2008, 10:30 PM
