Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Battery Relocation.... circuit breaker size?
  1. #11
    Site Supporter Javal's Avatar
    Josho
    Very normal and not dodgy when done correctly. Many many modern cars have this setup.
    Either way is fine mate as long as they're done properly. Using the starter terminal as a common point will reduce the amount of cable required and could give a neater appearance depending on how you do it. All down to personal preference, I have 2 seperate cables for alternator and starter which join at the battery, however my starter motor is on the opposite side of the engine to the alternator, so I didn't really have a choice.
  2. #12
    Mar 2011
    Ali
    OK, I'll consider it....as long as I can get it looking neat and all it might be the way to go.
    I have another question in reference to earths.
    The existing earth cable also ran to the starter, to a mounting bolt.
    This seems to be the only battery -ve earth point.
    I was thinking of ditching it for a series of 3 to 4 smaller cables.
    Battery to body (style side ute tub mounted on rubber blocks)
    Battery to body (Front cab also on rubber blocks)
    Body to gearbox
    Body to engine
    Yeah? or is there a reason why this was done with single cable?
    What would you do?
    Ali
  3. #13
    Josho
    We'll anything you want to earth to all needs to get back to the battery eventually, but your plan sounds pretty solid. Just make sure the engine to body and the body to battery earths are nice heavy gauge stuff, as those will carry all the current for starting and charging. The others can be of a smaller gauge but still use decent gauge stuff, headlights / high beams / blower motors / big stereos etc are all high draw.
  4. #14
    Mar 2011
    Ali
    Thanks for the info Josho!
    Yep, just to clarify, 3 - 4 smaller length cables of made from 2 guage.
  5. #15
    Josho
    I used the biggest stuff I could find (I think it might have even been 1 gauge? Maybe 2 gauge. Whatever the heaviest duty stuff Jaycar has) for the engine to body and body to battery. The gearbox to body earth was a factory one, which is really quite small. You won't need heavy stuff for your rear tub as all you'll really be running is the rear lights, but use big stuff for the cab-to-chassis, engine-to-chassis and chassis-to-battery.
  6. #16
    Mar 2011
    Ali
    I googled the hell out of this, but I was lost in the amazing amount of info and different ratings.
    I have used 25mm2 welding cable from battery to starter, its about a ~2m run (ute).
    The cable stated 230amp, but I'd reckon that would be maximum peak..
    How do I work out the "working" current / continuous rating for this size cable?
    One site stated 170A, but I don't know if this is correct?????
    Cheers,
    Ali
    EDIT:
    I rang battery world - guy stated 25mm2 is close to 3AWG and has maximum peak of 200 amp.
    He then said 190 Amp would be the safe working current...
  1. Ice breaker
    By Noddy in forum General Topics (No Technical Questions)
    Last Post: 27th July 2011, 11:29 AM
  2. WTB: 3tc Battery tray and 3TC battery hold down
    By kul_blu_car in forum Cars or Parts Wanted
    Last Post: 18th February 2011, 06:34 AM
  3. WTB: Spacer for boss kit / steering wheel, wind breaker
    By AE86.cn in forum Cars or Parts Wanted
    Last Post: 21st May 2008, 02:35 AM
  4. Which Size Battery
    By SIC86 in forum Technical - Questions
    Last Post: 20th July 2005, 08:53 PM
