Results 1 to 7 of 7
Thread: Blacktop ITBS vs Silvertop ITBS
    Mar 2011
    Ali
    Default Blacktop ITBS vs Silvertop ITBS
    Car - Toyota AE71 Pano
    motor / part in question - ITBS
    problem - Actual Sizing
    occurs/started when (if applicable)- Bought ITBS
    personal situation (if applicable)- N/A
    What size are AE111 ITBS
    And what size are AE101
    Been searching for the answer and come up with different answers.
    I bought some ITBS, spose to be BT, but measure 47mm at the opening where stack bolts on
    Says AE111 47mm, AE101 45mm
    Says AE111 45mm, AE101 42mm....
    then states
    Silvertop ITB's measure 47mm at the opening where the velocity stacks bolt up.
    Blacktop ITB's measure 49mm at the opening where the velocity stacks bolt up.
    On the backside of the silvertop ITB's they are round.
    On the backside of the blacktop ITB's they are an odd diamond shape.
    Says AE101 45mm
    Can someone who knows please help a wigga out.
    Mar 2011
    Ali
    Default Measurements taken
    Upper measures 47mm
    Lower measures 42.5, and is perfectly round
    I think they are Silvertop....Don't Blacktop have a strange shape at the lower end?
    West
    Theres a great photo online comparing them all.
    There are more distinctions than bt or st. Theres st early, st late and bt afaik. So within silvertop there are 2 slightly different variants from memory.
    Theres a photo someplace online that compares the ports of all three.
    West
    Mar 2011
    Ali
    Thanks for the info Matt.
    I never even knew there were Silvertop early and late!
    I was of the opinion that Silvertop ITBS were 48mm at opening where stack bolts on, and Blacktop were 50mm.
    This was because TODA sold velocity stacks as 48's and 50's.
    I would like to see the TB's pulled off the Manifold and measured up on all variants and referenced for all to see.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Those you have pictured are silvertop, likely gen 2.
    The easiest way to tell from the front is the mounting bolts for the velocity stacks are 73mm center to center, but on the black they are 83mm.
    As for the back the silvertop are round and the blacktop aren't.
    Mar 2011
    Ali
    Thanks for the info Sam.
    Silvertop it is.
  1. F.S Silvertop ITBs melb
    By burcoty in forum Car Parts For Sale
    Last Post: 28th May 2014, 11:16 AM
  2. WTB blacktop itbs bris
    By toyotakraze in forum Cars or Parts Wanted
    Last Post: 1st August 2013, 05:42 AM
  3. silvertop itbs with TPS NSW
    By sideburns in forum Car Parts For Sale
    Last Post: 18th April 2013, 07:44 PM
  4. Blacktop ITBs Stacks/Trumpets
    By Eircamae86 in forum Cars or Parts Wanted
    Last Post: 26th March 2009, 04:38 PM
  5. Blacktop Itbs
    By damo46 in forum Technical - Questions
    Last Post: 16th May 2008, 04:01 PM
