Results 1 to 2 of 2
Thread: Smallport RWD top radiator hose.
    Aug 2012
    Jarrad
    east
    Default Smallport RWD top radiator hose.
    Hi, quick question.
    What radiator hose/ Part number are people running the smallport top water outlet using?
    I believe the standard ae86 rwd part is too short.
    It's a piece holding me back and need to know as soon as possible.
    Thanks.
    Aug 2012
    Jarrad
    east
    I will post here for further info for people.
    A stock 4AC/4AGE top hose 100% will not fit. Too short.
    A Bottom radiator hose moved/chopped WILL fit. You have to cut it short (will post a pic)
    Your other option is two 90 degree (the tightest/smallest radius bend) and join them in the middle. This allows you to get many different angles and cut/play with fitment. But if it is a gentle bend in the 90 degree/a large radius, it's hard to make fit.
  1. WANTED: 4AGE 16v RWD Head Water Outlet (Top Radiator Hose)
    By belstaff in forum Cars or Parts Wanted
    Last Post: 6th June 2014, 08:11 AM
  2. Wanted: rwd 4age top hose inlet pipe
    By mc68 in forum Cars or Parts Wanted
    Last Post: 26th October 2013, 08:12 AM
  3. 20V RWD Converson - Bottom Radiator Hose?
    By Futo_gt86 in forum Technical - Questions
    Last Post: 25th October 2011, 12:46 AM
  4. Wanted. 4age top hose outer from the block to the radiator
    By porter in forum Cars or Parts Wanted
    Last Post: 30th March 2011, 12:29 AM
  5. Jdm 4ag Into Ae71 With Ae71 Radiator, Which Top Hose
    By Trev084 in forum Technical - Questions
    Last Post: 1st April 2009, 03:40 PM
