Results 1 to 3 of 3
Thread: Thermo fan help
    Senior Member pieman18's Avatar
    Dan
    Caulfield South
    Default Thermo fan help
    Hey guys
    It's been a while since I've posted on these forums, I still come in here regularly however, and I also remember how smart everyone here is...
    I'm about to replace the old, broken stock radiator with a new alloy radiator with thermo fan and shroud in my project car (1981 vc commodore 308)
    It's a straight swap so installation will be the easy part
    It's the connections on the thermo fan I'm not too sure on
    The old radiator has a 9inch thermo fan attached which actually works well. It uses what looks like a Davies Craig thermo switch kit, I just need to know how to connect to it...
    The new thermo has these connection points
    If anyone knows how to connect these points to the switch or can offer any help at all, it would be appreciated
    Cheers guys
    Dan...
    Formerly: sprinters_r_mad
    Senior Member Dylan's Avatar
    Dylan
    How was the other fan connected to the thermo switch?
    You could just use bullet terminals (which is on your new fan) to connect to the thermo switch, just need to get the polarity correct otherwise it will spin the opposite way.
    The black wire can be connected to a good ground
    Eddie
    One goes to +ve, one to -ve. Reversing them will reverse the air flow through the fan. The switch will either earth or give power when the temp trips. Just get a multimeter to test it.
    Sent from my iPhone using Tapatalk
  1. Thermo fan wiring
    By quoccy in forum Technical - Questions
    Last Post: 17th October 2009, 02:09 AM
  2. Thermo fan Setup
    By wideslider in forum Technical - Questions
    Last Post: 3rd September 2008, 10:06 PM
  3. Thermo Fan/s
    By acidreign in forum Cars or Parts Wanted
    Last Post: 8th April 2008, 12:54 PM
  4. thermo fan
    By AE86_4life in forum Technical - Questions
    Last Post: 31st January 2007, 11:32 PM
  5. Thermo Fan
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 8th November 2006, 11:46 AM
