As a clutch wears it gets higher up, not lower... the pressure plate back sticks out towards the thrust more.
Try bleeding it again?? If the mechanical side of it like the thrust fork & seals are OK it must be in the hydraulics.
Somehow you're not getting enough thrust distance out of it. Does it rest with the thrust bearing just sitting on the pressure plate?? No play in the fork before you press the pedal?
