PRICE DROP $5000 without wheels
1983 KE70 Corolla
4AGTE Swap
Small port 7-Rib bottom end
Big port head
T28 Runs 15PSI
2.5" straight through exhaust with a rear muffler
Front mount
Aluminium radiator
Relocated Oil Filter
Aeroflow oil cooler
Genuine Bosch 044
In boot surge tank
Facet lift pump
Adaptronic e420d
T50
Ceramic 5-puck clutch
212mm Flywheel
T18 T Series Diff
KAAZ 2-way LSD
AE86 front BC Gold Coilovers @ 8kg spring
AE86 brakes
AE86 LCA
AE86 P/S arms
Whiteline front swaybar
Whiteline rear swaybar
AJPS 215mm rear springs @ 6kg (shortened)
KYB short stroke rear shocks
Whiteline Adjustable Panhard Rod
SSR Formula Mesh 14x8 -5 185/55 +20mm spacers
Volk Mesh 14x8 -10 185/55
Originally slant front KE70
Quad lights
Flat front quarters and bonnet
T18 front bumper
Welded (tacked on) metal rear flares
Bride (rep) adjustable bucket seat
Water temp gauge
Boost gauge
Battery relocated to boot
Has a mod-plate for a N/A 4a-ge conversion
Owned this car for over 3years and have never had any major issues with it.
Made over 160kw with a 2.25" exhaust with a cat in it, but the exhaust was choking it up.
So got a 2.5" system built for it and now makes far more than that, especially up in the high rev range.
Body and paint pretty rough, little bits of rust in the boot but no serious chassis rust in it.
Located in Toowoomba
Rhett - 0448 969 231
Pictures here:
http://www.rollaclub.com/board/topic/72717-ke70-4a-gte-coilovers-2-way/
bump
