The Toyota 86 is a sports car released in 2012 featuring a horizontally opposed 2.0 L 4U-GSE / FA20 H4 boxer engine incorporating Toyota’s cutting edge D-4S direct injection system, to create a fiery package boasting 147kW of power and a 7,400rpm redline. The front-engine, rear-wheel drive vehicle is available with a 6-speed triple cone synchro manual transmission or a 6-speed automatic transmission while the rear differential is a Torsen Limited Slip Differential with a 4.1:1 ‘performance’ Final Drive Ratio. The LSD can help maximise traction by allocating power to the drive wheel with the greatest amount of grip.
In the handling and safety department Anti-lock Braking System (ABS) controls braking pressure and there’s Vehicle Stability Control (VSC) and VSC Sport to control the braking force delivery to each wheel under emergency braking conditions. Electronic Brake-force Distribution (EBD) maximises braking efficiency by automatically increasing the brake force to the wheel(s) that need it most, while Brake Assist5 (BA) will allow extra brake pressure during an emergency situation. GTS models are fitted with 294mm and 290mm discs and GT’s 277mmm and 286mm discs, respectively.
NEED HELP CHOOSING THE RIGHT BRAKE PAD?
Part numbers for GTS models:
Front Brake Pads – Part No: DB1491
Fits: Toyota 86 GTS (294mm Disc/ 290mm Vented Disc) 2012 – NOW
Set consists of Left and Right Inner + 2 Outer Pads
Rear Brake Pads – Part No DB1789
Set consists of 4 Pads 111 x 40 x 17 mm
Part numbers for GT models:
Fits: Toyota 86 GTS (277mm Disc/ 286mm Vented Disc) 2012 – NOW
Rear Brake Pads – Part No DB1803
Fits: Toyota 86 GTS (277mm Disc/ 286mm Solid Disc) 2012 – NOW
Set consists of Inner with Sensor + Plain Inner + 2 Outer Pads
Available from your local Bendix stockist. Locate your nearest stockist here:
