Results 1 to 6 of 6
Thread: Question about W57 shifter position and AE70
    Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Question about W57 shifter position and AE70
    Hey guys,
    I got a w57 gearbox for my 1uz Ke70 build. However, the box has a weird shifter on it. Same as the one in the link
    [http://images.google.com/url?q=http:...jZwfQe6RF-RIg] is good,have a look at it!.
    Does anyone know if it will fit without modification of the stock gear hole?
    Please advise
    Site Supporter Javal's Avatar
    Josho
    That's the remote shifter in the link. Furthest back out of the 7 different shifter positions available. No, it probably won't go through the stock hole, but you never know.
    The six shifter housings along the bottom are for W55/56/57/58, along with the remote shifter on the right. The top four are for the W50 steel case box.
    There's one sure way to know which shifter position you need - Measure it. Engine mounting will determine where your gearbox sits, so sort that first, then follow the measuring guide Goldberg made here to determine what shifter position you need - http://www.ae86drivingclub.com.au/fo...ones-Available
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Thanks Javal!
    I'll have to fit the engine first then follow the measuring guide. But after reading that link, my guess is it probably won't fit, especially since I'd like the engine mounted as far back as possible.
    And, I've seen another thread by Goldberg, where he says that this particular extended shifter setup requires an additional shaft for it to fit AE86 /KE70... I'm yet to see a pic of the said shaft.
    Back to parts hunting
  • #4
    West
    So does anyone have the part number for the third one along on the bottom row and the little knuckle that goes with it? I need to switch to it and Goldberg has disappeared.
  • #5
    West
    I was able to buy the housing from dellows, a copy of oem, but not the knuckle below to the rail, so Ill just modify mine I think if the gearbox shop doesnt have one.
  • #6
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Hey man, I hope you were able to get the parts. I discovered that the old celica supra shifter setup fits perfectly in the KE70, with the 1uzfe and W57 gearbox. I got the whole setup brand new online from a toyota parts retailer in the US. (Can look for the website if you like).
    Sorry for the late reply.
    Max
  • Similar Threads
    1. AE86 / KE70 Shifter position on body
      By ae86 in forum Technical - Questions
      Last Post: 3rd October 2012, 10:51 PM
    2. [TAS] WTB: W55-58 rear position shifter housing
      By mrraven in forum Cars or Parts Wanted
      Last Post: 23rd March 2011, 01:24 PM
    3. w58 shifter position into ae86
      By redsprinter in forum Technical - Questions
      Last Post: 23rd March 2009, 10:00 AM
    4. W58 question indentify/shifter position
      By Maxhag in forum Technical - Questions
      Last Post: 15th September 2008, 10:33 PM
