What knuckles do you run?
they definitely fit with out need for a longer bolt, although they are tight
I 'wrapped' mine around and then it worked well, I think it has to do with the corners, unless you really force them in there they sit slightly proud.
I use a flos rack in one of my cars and a quaife in the other, both have performed well so far
MOPAR or no car!
end result is going to be stock, ps ae86 arms or t3 arms on ra40 struts.
at the moment is ra60 struts n knuckles, which is horrible.
if i dont get the new brake upgrade done in time on the ra40 struts, ill use the ra60 strut with t3 hybrid knuckles so i can run the big brakes that i run on that setup. untill ra40 setup is done.
