Results 1 to 4 of 4
Thread: JDM Corolla : Oil Cooler + Oil Temp Gauge
    Aug 2011
    George
    Sutherland Shire
    Default JDM Corolla : Oil Cooler + Oil Temp Gauge
    JDM AE92: Oil Cooler + Oil Temp Gauge
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Unless you're running slicks and/or decent aero the standard sump is adequate, especially so with extra baffles.
    Standard oil cooler setup however is rubbish, and a proper full flow setup is worth the money. -8 or -10 will be fine for the lines. If you've bought a new sump welding a bung on the side for an oil temp sensor is easy before you fit it to the car.
    Aug 2011
    George
    Sutherland Shire
    Thanks for that Jimmee; in that case I think I'll pull the trigger on the MRP thermostatic adapter @ below but will hold off getting their 15 row cooler for now.
    I'm not a big fan of running braided hose every-where & even though its a PITA will investigate feasibility of buying a manual Tube bender + Flare kit & replicate the OE hard-lines in AN-8 mild or stainless-steel. I'll also look for a cooler closer to the dims of the OE unit so I can use OE brace / mtg points.
    PS: On a related matter; my 4AGE is a big-port with no oil drain from the head to block. Is there any way I can tap an oil drain in the back of the head w/o getting metal shavings / swarf in the oil-ways? I've heard smearing the cutting bit with grease helps but am worried that even a minute amount of swarf may damage the bearings / engine.
    Mar 2011
    Mt Dandenong
    Definitely don't try and drill and tap with the engine together, not worth the risk. Take the head off if you're going that way.
  1. hks 60mm temp gauge 130$
    By toyoda in forum Car Parts For Sale
    Last Post: 17th December 2009, 08:35 PM
  2. jdm cat temp gauge
    By tim.duncan in forum Technical - Questions
    Last Post: 4th September 2008, 08:25 AM
  3. Oil temp Auto gauge 2' Electrical
    By reecegze in forum Car Parts For Sale
    Last Post: 2nd July 2008, 12:08 PM
  4. Omori mechanical oil temp gauge
    By racsov500 in forum Car Parts For Sale
    Last Post: 17th May 2008, 05:31 PM
  5. engine temp gauge
    By Johnny_08 in forum Technical - Questions
    Last Post: 18th April 2007, 11:59 PM
