Results 1 to 3 of 3
Thread: Fuel pump always running after ignition off
    Feb 2017
    Steve
    WI
    City
    USA
    Default Fuel pump always running after ignition off
    So I just bought a 1985 Corolla GTS today and when I got home, i noticed that I could still hear the fuel pump even after I take the keys out. I think it's the wiring but I'm a complete noob at wiring. Any ideas how I should go about it? Just point me in a somewhat specific direction if you can. Thanks.
    Also, was told that it is running a supra fuel pump
    Feb 2017
    Steve
    WI
    City
    USA
    Okay im stupid. I've been driving newer cars so I never had this but I guess there's a button i have to press by the key to fully turn off the car lol. /closethread
    Mt Macedon
    If the engine is off and the fuel pump still runs then something has been setup badly. From factory the fuel pump is run by a circuit opening relay (COR) that powers it when starting and when the engine is running. This means if you crash then it won't keep pumping fuel into the wreck.
    There are a few possibilities for wiring the pump:
    - Use a COR like factory.
    - Use two normal relays in parallel.
    - If it runs an aftermarket ECU use the ECU output.
    - Run a tachometric relay. VK Commodores run them, or apparently they are used in gas conversions too.
  1. Replies: 0
    Last Post: 17th October 2015, 10:16 PM
  2. 4AC fuel pump - replace mechanical pump or put in eleectic pump?
    By Sprinterman in forum Cars or Parts Wanted
    Last Post: 19th March 2012, 07:57 AM
  3. Fuel system, surge, efi pump and lift pump
    By skin in forum Car Parts For Sale
    Last Post: 31st October 2010, 10:22 PM
  4. AE86 4A-GE no spark and fuel pump not running
    By Brendan in forum Technical - Questions
    Last Post: 14th May 2010, 04:03 PM
  5. Replies: 2
    Last Post: 5th April 2010, 06:54 PM
