Results 1 to 6 of 6
Thread: Jacking car up question
    Feb 2017
    Steve
    WI
    City
    USA
    Default Jacking car up question
    Sorry dumb question but i have to ask. My 85 gts e brake cable is snapped. I have a new cable but i need to get under the car. Would the car roll if I jacked the front but left it in gear?
    Your best bet is to put a brick or something in front of the car so it doesn't roll. It shouldn't roll in gear, but it can.
    Feb 2017
    Steve
    WI
    City
    USA
    So i should jack from the rear and put bricks at the front tire then instead of jacking the front, bricks at rear tires?
  • #4
    Senior Member Brendan's Avatar
    Brendan
    Yes it can roll if you jack the rear up, if you leave it on the jack by itself. Use axle stands to be safe and bricks in front of the the front wheels.
  • #5
    May 2017
    Donaire
    FL
    Jacksonville
    United States
    I agree on using axle stands. There are cheap ones that are still sturdy.
  • #6
    Mt Macedon
    Jack whichever end you need to get up in the air. Replacing the handbrake cable would likely be possible with only the rear on stands, though it might be tight at the lever end.
    Always chock the wheels on the ground so that they don't roll. Always use jackstands if you're going to get under a car, and if you are taking wheels off then lie them under the chassis rails too as a backup.
  • Similar Threads
    1. Car jacking in North Sydney
      By Leigh in forum Sydney & NSW Events and Discussion
      Last Post: 4th August 2009, 08:10 AM
    2. Quick clutch question and spigot question
      By wideslider in forum Technical - Questions
      Last Post: 9th August 2008, 12:45 AM
    3. Question.
      By hugh in forum General Topics (No Technical Questions)
      Last Post: 11th November 2007, 05:05 PM
    4. ecu question!!!!!
      By haydenzz in forum Technical - Questions
      Last Post: 15th August 2007, 08:57 AM
    5. Question....
      By arod in forum General Topics (No Technical Questions)
      Last Post: 25th June 2007, 09:06 PM
