Results 1 to 1 of 1
Thread: Top Tips for Road Trips
    Member Bridgestone's Avatar
    Sep 2014
    Rob
    Seven Hills
    Default Top Tips for Road Trips
    Thereís nothing quite like getting out on the road and escaping the city for a week or two. A road trip can be a lot of fun, but failure to properly prepare can quickly turn your road trip into a nightmareÖ
    Poorly prepared cars can cause unwanted headaches, thereís risk of tyre failure, not to mention all of the little things that can go wrong. So, before you get behind the wheel, check out our top tips for road trips.
    Inspect your tyres
    We recommend you keep a good close eye on the condition of your tyres Ė not just when preparing for a road trip but all the time. Only one hand print of tread connects each tyre to the road and if theyíre overly worn or incorrectly inflated they could cause you some trouble.
    We expose our tyres to some harsh conditions in Australia. Under-inflation is a major problem which can be controlled with regular tyre maintenance. An underinflated tyre will cause an increase in stress, concentrated on the sidewall of the tyre. These stresses result in heat build up which can lead to tyre damage and ultimately result in a blowout.
    Under-inflation can also increase fuel consumption, tyre wear and braking distance. Bear in mind though, if you check your tyre pressures after youíve been driving for a while the pressures will be higher, due to the air inside the tyres expanding when hot.
    Donít deflate your tyres; ensure you check your tyre pressures when they are cool.
    Check your cooling system
    Itís also worth giving your cooling system a good once-over before heading off on a road trip.
    Make sure you check your coolant levels and that your fan is working. You should be able to hear it running when driving and your temperature gauge shouldnít move far past halfway. If it does, or it starts to rise suddenly when youíre driving, pull over immediately to see what might be the problem.
    Pack what you need
    It can be tempting when heading off on holidays to pack everything including the kitchen sink, but overloading your car can reduce its handling ability, and increase your fuel consumption.
    So, make sure you know what your carís maximum payload is and donít exceed it.
    More than that, donít load up your car so much that you canít see out of the windows.
    Drive to the roadís conditions
    The surfaces of freshly sealed or older roads can have looser surfaces, especially when they heat up. Gravel flicking up from the road can cause damage to your carís underbody or other vehiclesí windscreens.
    So, if the surface is loose, slow down and increase the distance between you and the car in front; you donít want to get a cracked windscreen.
    Prepare for the glare
    Make sure your windscreen is in good condition and clean, that your windscreen washer bottle is full and your wipers are in good condition.
    Also make sure youíve got a decent pair of sunglasses, preferably with polarized lenses for long distance driving, especially if youíre driving in summer. A quality pair of sunnies are a must have, because nothing tires you out like squinting behind the wheel. If the glare gets too bad, you could even momentarily lose sight of the cars in front.
    And make sure youíve got plenty of water in the car when youíre driving, because drying out can increase fatigue.
    Be aware of other road users
    If youíre heading to a popular holiday spot, it can feel like every man, woman, child and their dog is out in their cars, on their bikes, or even their skateboards! This means youíve got to be extra careful when on the road.
    Always scan the road ahead, to the side and the rear, for other cars and particularly motorcycles. Never rely only on your mirrors; always perform a shoulder check.
    Oh, and donít ever, ever use your phone when youíre driving, place it in the glove box out of reach.
    Inspect anything youíre towing
    If youíre hauling the family caravan, camper trailer or boat on your holiday, make sure youíve thoroughly checked over your rig before hitting the road.
    Just as itís important to check the tyres on your car, itís also vitally important you check your tyres on whatever youíre towing. Why? Well, theyíre often sitting around in one spot for months on end, which can lead to flat spots on the tyre. This will result in a vibration for the first few kmís of your journey but should return to normal as the tyre regains its shape. However this damage can be permanent if the tyres havenít moved in a really long time.
    Youíll also want to make sure the bearings and brakes are up to scratch, and that thereís no mould on the vinyl of the pop-top if youíve got a pop-top caravan. Itís worth it if you havenít had your caravan or camper trailer out in a while, to take it to a caravan mechanic for a thorough once-over.
    Always check your spare
    Itís one thing to give your tyres a regular visual inspection, but donít neglect your spare tyre.
    Some new cars donít even have a spare, they have an inflation kit. If your car does have a spare tyre get it out and take a good look at it, check the pressure and inflate it if need be. Check your tool kit while youíre there, too. It doesnít hurt to carry a few extra bits and bobs like spare fuses.
    Take a break
    Youíve all seen the roadside signs about fatigue and some of you may have ignored them. Donít.
    Plan longer journeys so that you can take regular breaks (about every two hours) of around 20 minutes or so. Stop at a park and go for a walk or a jog, anything to get the blood flowing again. Even have a short nap, but make sure your car is parked somewhere safe when you do that.
    LINKS:
    Bridgestone Australia - www.bridgestonetyres.com.au/
    Bridgestone Australia Facebook - www.facebook.com/BridgestoneAU
  1. Top Tips for Summer Road Trips
    By Bridgestone in forum Bridgestone
    Last Post: 20th December 2016, 02:19 PM
  2. Expert Tips for On-Road Tyre Pressure
    Last Post: 13th December 2016, 10:50 AM
  3. diy respray tips
    By alex.wilson in forum Technical - Questions
    Last Post: 23rd November 2009, 07:57 PM
  4. Wiring tips
    By 4A-GE Power in forum Technical - Questions
    Last Post: 23rd October 2005, 01:18 PM
