Results 1 to 4 of 4
Thread: Wheel Cylinder Size for KE70 with Brake Upgrades
    Aug 2013
    Graham
    Default Wheel Cylinder Size for KE70 with Brake Upgrades
    I've upgraded the front brakes and master cylinder on my KE70 and need to know what size wheel cylinders I should be running. I've got RA65 front brakes and T-series drum rear end with a Pajero Master cylinder.
    The stock setup is 13/16" master cylinder, 2" front calliper pistons and 13/16" wheel cylinders. With the upgrades I've now got a 15/16" master and 2 1/4" front callipers.
    Do I need to go with larger diameter wheel cylinders to keep everything balanced or will 13/16" be OK?
    West
    What do pajeros run inside their drums? Id run that as the wheel cylinder size.
    When i designed mine I chose parts that worked with the stock MC, so I chose Ra40 struts and fitted ae86 wheel cylinders in the drums on the F series and it all works perfectly with stock MC.
    I dare say you are moving more fluid than a T series drum rear end would normally have pushed at it, considering the mc has the same piston travel but a larger piston diameter. Therefore the wheel cylinder you use will need to process a larger amount of fluid. I would assume the change to a 15/16 mc would need a change to a 15/16 wheel cylinder if the stock sizes are 13/16 and 13/16. If you used a 13/16th wheel cylinder you would probably find there was a tendency to lock the rear drums, which is fatal.
    I found an amazing catalogue that lists a shot tonne of different brake parts and their hydraulic sizes. Ill see if I can attach it, Ive used it so many times.
    File is too large, PM me and I can email it.
    Aug 2013
    Graham
    Thanks, PM sent.
    My main concern is locking up the rears due to the change in bias caused by the larger front brakes. It looks like RA60's run a 7/8" rear wheel cylinder so that might be the way to go.
    West
    The similar era toyota drum wheel cylinders are a very common design with just different bores. If you control F the catalogue then you can find every entry with that size. Most cars have the bore sizes listed.
  1. KE70 Stock Brake Master Cylinder in Sydney
    By wideslider in forum Cars or Parts Wanted
    Last Post: 12th March 2014, 09:33 PM
  2. SA: NEED ASAP KE70 Brake Master Cylinder
    By Hazzard in forum Cars or Parts Wanted
    Last Post: 2nd May 2012, 06:06 PM
  3. working ke70 brake master cylinder in sydney
    By Sprinter Freak in forum Cars or Parts Wanted
    Last Post: 20th November 2011, 03:26 PM
  4. r33/jzx100 b/m cylinder size
    Last Post: 6th May 2010, 02:01 PM
  5. master cylinder bore size
    By dr1ft-pig in forum Technical - Questions
    Last Post: 2nd September 2008, 09:43 PM
