Results 1 to 3 of 3
Thread: Can't get wheel hub assembly off?
    Feb 2017
    Steve
    WI
    City
    USA
    Default Can't get wheel hub assembly off?
    I have an 85 gts hatch, trying to replace the front wheel bearings but i can't get the hub assembly off at all. Tried using hammer, a puller but no luck. what could be the problem? I took off the cap, pin, star, nut, washer and calipers already
    West
    Does it turn? It just sits there, usually, I cant imagine a mechanical reason other than it is seized together where the bearing meets the tapered surface, and this should be free if its rotating and greasy inside. Might have a bent stub axle.
    I prescribe a bigger hammer. A slide hammer would be ideal like you use when you pull an axle from a diff.
    Feb 2017
    Steve
    WI
    City
    USA
    yeah the hub can spin normally
  • Similar Threads
    1. Handbrake assembly
      By bigm in forum Technical - Questions
      Last Post: 25th February 2013, 07:53 AM
    2. anyone looking for a job doing automotive assembly?
      By NIZLAH in forum Brisbane & QLD Events and Discussion
      Last Post: 29th September 2012, 07:24 PM
    3. Tophat Assembly
      By GOODY in forum Technical - Questions
      Last Post: 17th July 2009, 12:24 PM
    4. WTB: T50 Shifter assembly
      By intense in forum Cars or Parts Wanted
      Last Post: 18th May 2008, 04:50 AM
    5. S13 brake assembly
      By paulie in forum Car Parts For Sale
      Last Post: 25th June 2007, 06:54 PM
