Results 1 to 4 of 4
Thread: 4AGE 20V Swap into AE86 Vacuum Hose Diagram
    Jun 2016
    RANDY
    CA
    LOS ANGELES
    United States
    Default 4AGE 20V Swap into AE86 Vacuum Hose Diagram
    Hi there,
    does anyone have a detailed vacuum hose diagram of the 20v blacktop swap?
    there used to be some good ones but some can't be accessed any more.
    Thank you
    Mar 2011
    Ali
    Found this on youtube, it might help out.
    https://youtu.be/tLcVH8DRuEc
    Jun 2016
    RANDY
    CA
    LOS ANGELES
    United States
    for the hose that goes to the VSS solenoid (evap), if there is no VSS solenoid (Haltech ECU), then what should be done with it?
  • #4
    Mar 2011
    Ali
    Here is a good site for working out vacuum lines, but its for silvertop....
    http://www.my-acoustic.com/Car/vacuu...39;_vacuum.htm
    I'm not to sure exactly.
    My method was to delete ISV, EVAP and blank off fuel pulse dampener.
    Basically romoved the entire rats net from underneath the Quads.
    I am of course using an aftermarket ECU
    This is also what I did on my last Silvertop motor also running stand alone ECU.
    Below is a simplified diagram of what goes where.
    Perhaps you could block off the evap lines? or maybe loop them?
  • Similar Threads
    1. 4AC vacuum diagram/car wont run problem
      By FergusB in forum Technical - Questions
      Last Post: 8th May 2010, 02:30 PM
    2. Silvertop 20v vacuum/fuel hose connections??
      By dtour in forum Technical - Questions
      Last Post: 19th August 2009, 06:09 PM
    3. why is the Vacuum hose not connected??
      By DK86 in forum General Topics (No Technical Questions)
      Last Post: 27th June 2007, 07:29 PM
