Results 1 to 2 of 2
Thread: I need help identifying these connectors on my harnesses
    Feb 2017
    Arvin
    New York
    Queens
    United States
    Default I need help identifying these connectors on my harnesses
    I have two GTS dash harnesses. Each of them have some different connections.
    Both have the connection for this relay which is on the passenger side
    However only one harness has the connection for this relay. The harness that doesn't have this connection has no trace of it. It looks like it was never there. This relay is also by the passenger side
    By the passenger Junction box there are two different cables. One is grey and the other yellow. What are they used for?
    Grey:
    Yellow:
    I have a GTS engine bay harness that seems to be missing connectors. I don't know if it is. It seems to have all the connectors to where it plugs into the driver side junction box, which is three. If there's more please let me know. On the passenger however, there's only one brown connector which I believe gives power to the junction box.
    If anyone can help me that'll be great.
    Thank You
    I've edited the post so the pics show up so it's easier for people to look at what is going on...
    Dash side this plug that you are unsure of connects into the ecu, it is not uncommon for it to be cut off when people are converting a car to 4age.
    It is extremely difficult to source the plugs on the loom, so your best bet might be to find a complete GTS loom that isn't missing any plugs.
  • Similar Threads
    1. Mint digital dash 46 xxx on the clock with connectors
      By Taylor13 in forum Car Parts For Sale
      Last Post: 19th October 2010, 09:35 PM
    2. Identifying LSD
      By KurtHS in forum Technical - Questions
      Last Post: 30th May 2010, 10:26 AM
    3. Is it possable to buy crimp connectors to suit loom plugs?
      By munki in forum Technical - Questions
      Last Post: 24th November 2009, 10:43 AM
    4. Identify these 20v loom connectors!
      By jet111 in forum Technical - Questions
      Last Post: 4th September 2009, 09:30 AM
    5. 4 x toyota COP ignition and loom connectors
      By thanhngo in forum Car Parts For Sale
      Last Post: 1st November 2007, 09:32 PM
