Results 1 to 8 of 8
Thread: 4AGE 20V Blacktop - Microtech LT10S CAS wiring - Crank input 1 and 2
    Mar 2011
    Ali
    Angry 4AGE 20V Blacktop - Microtech LT10S CAS wiring - Crank input 1 and 2
    Car - AE71 Panel Van
    motor / part in question - 4AGE 20V Blacktop
    problem - Aftermarket ECU / Microtech CAS wiring
    occurs/started when (if applicable)- Wiring diagrams are generic, bad schematics!
    personal situation (if applicable)- Not sure
    Hi to anyone reading this, hoping some one can point me in the right direction.
    Have a 4age blacktop going in my panel van, up to wiring in ecu.
    All's going well up to CAS wiring, I searched and found out the pin outs for DIZZY/CAS....
    On the Toyota OEM CAS side of wiring I have;-
    Black wire = NE / Engine RPM
    Red wire = G1 / Crank shaft position signal
    White wire = G / G1-G2 common earth
    Green wire = G2 / Crank shaft position signal
    *if incorrect can someone point out
    On the Microtech 4 pin Crank input wiring I have;-
    Black wire = GRND [which I take it is G]
    Red wire = Not Connected [Used for Fuel only config]
    White wire = Crank input 1 [is this engine RPM or Crankshaft position signal?]
    Green wire = Crank input 2 [is this Crankshaft position signal or engine RPM ?]
    After scouring the internet for many many hours/days, I cannot work out if crank 1 is NE or G1 or G2
    same for Crank input 2 or which Crank signal wire the Microtech wants - G1 or G2......
    I can't access the CAS to pull down and physically look, as no room, firewall too close....
    Any help would be much appreciated.
    Thank you for reading.
    Ali
    Mt Macedon
    G1 and G2 are the same signals, just 180degrees out of phase. They give a single pulse for each dizzy revolution. So (for example) you get G1 just as cyl 1 is firing and G2 just as cyl 3 is firing.
    NE is a constant rising and falling signal, 24 pulses per dizzy revolution if I remember correctly.
    Can't help with how they connect to a Microtech, you'll have to find out which of Crank Input are used for which function. Sometimes these signals are called Sync and Ref too.
    Mar 2011
    Ali
    Have I got the Toyota CAS pin outs correct?
    I used Phil Bradshaw 20V ECU pin outs from this link
    I read on Toymods that earlier Microtech don't use G2, old thread from 2006, but I'm guessing that is still the case.
    ref -
    That thread is about the same question, only the wire colours from the microtech are completely different now, and the Blacktop CAS pin outs are also different colours to the GZE CAS referenced.
    Based on process of elimination,
    BT20V CAS - Microtech
    NE Black - ?
    G White - Ground
    G1 Red - ?
    G2 Green - Not connected
    My guess would be
    NE - Crank 2
    G1 - Crank 1
    Question is, if I get it wrong will it fry...
    Mt Macedon
    I'm afraid I've never played with 20Vs so can't comment on wire colours. But no, you won't fry things if you get it wrong. All signals are the same level and type, so if it's wrong it just won't run.
    And no aftermarket ECUs will use both G1 and G2, as far as I know. Connecting one is fine.
    Mar 2011
    Ali
    Just double checked BT20V CAS pinouts with this;-
    Phil Bradshaw's page is legit, all checks out.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    I experienced similar problem with a silvertop and microtech. Will check my notes when I get home and let you know
    Sent from my GT-S7275Y using Tapatalk
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Mar 2011
    Ali
    Thanks for that, eagerly awaiting info....
    Far out, I must have read every microtech post made since the invention of the internet...
    and this one is the closest thing I can find to an answer so far....
    But I don't trust the source.
    Mar 2011
    Ali
    Thought I'd just update this so it can be helpful for microtech users who got stuck like i did.
    BT20V Distributor (used as CAS) - Microtech LT10s 4 pin CAS wiring
    Distributor NE Black - Crank 2 / Green wire on Microtech LT10s
    Distributor G White - Ground
    Distributor G1 Red - Crank 1 / White wire on Microtech LT10s
    Distributor G2 Green - Not used
    Red wire from Microtech LT10s loom not used
    Black wire from Microtech LT10s grounded to vehicle chassis.
  1. HELP NEEDED 4AGE turbo microtech lt10s thermo fan wiring
    By Gorgi in forum Technical - Questions
    Last Post: 26th February 2013, 02:32 PM
  2. Replies: 19
    Last Post: 24th April 2010, 02:10 PM
  3. Microtech LT10S & 4age ecu
    By munki in forum Car Parts For Sale
    Last Post: 12th March 2010, 12:41 AM
  4. Replies: 5
    Last Post: 10th March 2010, 04:11 PM
