Results 1 to 4 of 4
Thread: running on 2 cylinders?
    Jun 2017
    chris
    Pennsylvania
    pittsburgh
    United States
    Default running on 2 cylinders?
    Hey all,
    I've had my 86 for about 6 years. ran and drove fine before I tore it apart 2 years ago for a minor restore and paint the entire chassis. I fianlly just got it all back together! feels great besides the fact that it only running on 3 and 4. 1-2 are dead. new dis cap. wire and plug were put in before i tore it apart and ran fine.it runs but like a bag of dicks, so i was able to pull 1-2 spark wire out and it has spark and are firing. so next step check injectors. I had a bad injector once befor and got 8 used one from a guy Know. so I change out the injectors and still no diffence. any one have some advice about trouble shooting this problem?
    thanks
    Senior Member Brendan's Avatar
    Brendan
    Definitely check the injectors. Test them out of the car if you can, even swap the 3rd and 4th cylinder injectors around with the 1st and 2nd cylinders to see if they will work in there.
    I "cleaned" my own injectors once by using a fuel pump directly on the injector, and using an old plug and a battery to open/close the injector over a bucket. Not sure if it was right but hey, it worked...
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Default only 2 cylinders
    The 1st and 2nd cylinders injectors are fire as a pair. High probability that you either are not sending a signal to the injectors or the injector are not grounding thru the ECU.
    Use a noid light or old style VOM [not digital] to verify that current is at the injectors. If you are getting a signal, then check the grounding wire for an open circuit. Dave W7
  • #4
    Jun 2017
    chris
    Pennsylvania
    pittsburgh
    United States
    Quote Originally Posted by davew7 View Post
    thats exactly what the problem was! I had power to the injectors but they wernt grounding. So i traced all the wiring back to the ecu and one of the pins was push out of the connector. now i just have a weird idle like a vacuum leak. Revs up and drops back to normal. My buddy said hondas do this all the time after sitting for a while, he said the ECU is just relearning it self? I'm not certain thats case, so I'll be checking all line and the TPS today. My engine harness pretty beat and connectors are falling apart, so that could be another problem also.
  • Similar Threads
    1. running on 3 cylinders
      By d1staz in forum Technical - Questions
      Last Post: 16th June 2013, 12:26 AM
    2. 7age running cold - changed thermostat and now its running hot
      By boh086 in forum Technical - Questions
      Last Post: 18th January 2011, 08:33 PM
    3. Blacktop 20V running on 2 cylinders
      By Adsie in forum Technical - Questions
      Last Post: 6th December 2010, 10:31 PM
    4. running on 3 cylinders
      By ae71ness in forum Technical - Questions
      Last Post: 29th November 2010, 10:13 PM
    5. Car seems to run on 3 cylinders
      By RB20DET_Silvia in forum Technical - Questions
      Last Post: 16th February 2006, 02:29 AM
