Results 1 to 9 of 9
Thread: AE86 Parts - Lots of items - NSW - Robertson
    Junior Member DGLEVIN's Avatar
    Robertson, NSW
    Thumbs up AE86 Parts - Lots of items - NSW - Robertson
    Call David 0404097401 or PM
    TRD T50 Close Ratio Gear Set. New in box with rebuild kit, syncro's and bearings. Purchased as spare not used. $2,500.00 - Sold
ID:	37583Click image for larger version.
Name:	Gear Set label.jpg
ID:	37584Click image for larger version.
    Toyota T series 6.7 inch Diff Centre 4.8 with TRD LSD. very good cond. - $1200 price reduction
Name:	Diff Centre 4.8 LSD.jpg
ID:	37561Click image for larger version.
Name:	Diff Centre 4.8 LSD pic2.jpg
ID:	37562Click image for larger version.
Name:	Diff Centre 4.8 LSD pic3.jpg
    Toyota T series 6.7 inch Crown and Pinion 4.3 including Planetary gears - $400.00 - Sold
Name:	4.3 Crown and Pinion.jpg
ID:	37564Click image for larger version.
Name:	4.3 Crown.jpg
    Koni Adjustable Front Inserts unused - Adjustable Sport 1991 4208 86 Pair - $60.00 - Sold
Name:	Koni Inserts.jpg
ID:	37571Click image for larger version.
Name:	Koni Inserts details.jpg
    AE101/AE86 4AGE 20v engine - Head and block - still excellent working condition when removed from race car - std unmodified. - $500.00 Sold
Name:	4AGE 20v pic2.jpg
ID:	37573Click image for larger version.
Name:	4AGE 20v pic1.jpg
    4AGE 16v Engine - Block and head only, fly wheel, engine mounts, computer no loom still working well when removed from car - Gone - Picked up
    AE86 Strut brace (non adjustable) - $50.00 - Sold
ID:	37576Click image for larger version.
    AE86 - Prop shaft - $100.00 - Sold
Name:	Prop Shaft.jpg
    AE86 - Std Fuel Tank 50Ltr - 50.00 - Sold
Name:	AE86 Fuel Tank Pic2.jpg
ID:	37579Click image for larger version.
Name:	AE86 Fuel Tank Pic1.jpg
    AE86 JDM Levin - Combination Meter - Redline 7,700 - $100.00 - Sold
Name:	AE86 JDM Combination Meter.jpg
    AE86 - Radiator Shroud with Davis Craig fan mounted - $100.00 - Sold
ID:	37582Click image for larger version.
ID:	37566   Click image for larger version.
ID:	37567   Click image for larger version.
ID:	37568   Click image for larger version.
Name:	Albino wheels.jpg
    Terry
    Ipswich
    are the wheels for sale also?
    Robertson, NSW
    Hi Terry,
    Yes wheels are for sale, I put them in the incorrect section, parts not wheels. Moved them to see below:
    http://www.ae86drivingclub.com.au/fo...-AE86-4-wheels
    http://www.ae86drivingclub.com.au/fo...lbino-4-wheels
    regards David G
  • #4
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Any comp or leakdown test numbers on the AE101 engine by any chance?
  • #5
    Robertson, NSW
    Hi James
    4AGE 20v engine, out of a AE101,
    Unable to say what to current test numbers are, but
    History, when I purchased it, the engine had 60k on it, it went into my race car as is for circuit racing, see other ad, race car for sale, I used it for 3 years doing a number of events, the engine did not miss a beat, when I
    pulled it out about 1 and half years ago to put in a full race engine, it was still going strong, it would probably only have a further 2000 ks on it but at race rev's, it would rev to 7,700 rpm all day, oil changed every race meeting.
    It has never been pulled apart, meaning head taken off for a rebuild. As is it will go well, pulling strong to rev limit 7,700 rpm.
    I have spare rods, std cams, cam gears which you can have.
    Regards
    David G
  • #6
    West
    This guys a great seller
  • #7
    Junior Member diz186's Avatar
    Shane
    Chippo
    Hi mate is the tank still available??
    Sent from my iPhone using Tapatalk
  • #8
    Robertson, NSW
    Hi Shane
    Yes the tank is for sale, even though I live out of syd, I am prepared to drop it off to Chipping Norton?
    regards
    David G
  • #9
    Junior Member sqezin's Avatar
    Mic
    Vic
    Any history on the diff? I take it that it takes 24mm axles.
  • Similar Threads
    1. JDM AE86 4AGE 20v Race Car - NSW - Southern Highlands - Robertson
      By DGLEVIN in forum Cars for Sale (Toyota Only)
      Last Post: 20th July 2017, 02:27 PM
    2. Replies: 8
      Last Post: 15th September 2015, 09:41 PM
    3. [SA] AE86 PARTS, lhs door, coupe boot, lots of interior parts
      By mark ii in forum Car Parts For Sale
      Last Post: 1st June 2011, 07:03 PM
    4. lots of ae86 parts
      By ash86 in forum Car Parts For Sale
      Last Post: 7th August 2007, 10:07 PM
    Tags for this Thread
