Results 1 to 9 of 9
Thread: Bloody Panda
    Jun 2012
    Jakob
    ACT
    Canberra
    Default Bloody Panda
    I've been lurking on this forum for a while now but haven't actually had an AE86... Until now. This finally arrived in Canberra for me a few weeks back.
ID:	37631Click image for larger version.
    I actually bought in December 2016 (thanks Troy from Iron Chef Imports). It took a while to get to me because it needed some parts for compliance (thanks Jack at Top Secret Imports). It had this awesome JDM-spec exhaust which was being held together by an Asahi can and a few other things that needed doing.
    Unfortunately the car carrier company cracked the front bumper somewhere between Sydney and Canberra but they're replacing and paying for paint under insurance, so that's ok.
    I finally got the time to work on the car this weekend. I replaced the whitelines with the correct redlines, and swapped out the bride bucket seat for an OEM GT Apex.
    This:
ID:	37635Click image for larger version.
    To this:
ID:	37637Click image for larger version.
    The rear axle was also making an awful noise (the main reason it got transported from Sydney to Canberra, rather than driven) so that's now out getting the crown wheel and pinion replaced, and the open centre swapped for a new OS Giken LSD. Looking forward to getting that back, bolting it back in and driving!
    West
    Nice pick up!
    Sep 2016
    Nick
    Sydney north shore
    I'll buy the bride and the taillights
    Sent from my SM-N9005 using Tapatalk
  • #4
    Jun 2012
    Jakob
    ACT
    Canberra
    Quote Originally Posted by kainer View Post
    Check the sales section!
  • #5
    May 2010
    Tyrone
    Caulfield
    Looks good!
    Stock 4age running gear?
    Sent from my SM-G935F using Tapatalk
  • #6
    Jun 2012
    Jakob
    ACT
    Canberra
    Probably not the original engine but stock intake manifold with TVIS and MAP sensor. I need a new air filter since the current intake is missing what I assume would have been a foam filter of some kind. It's just an empty funnel. I'll probably need to make some kind of box for ACT rego as well. Click image for larger version.
ID:	37647Click image for larger version.
    Sent from my Nexus 5X using Tapatalk
  • #7
    Jun 2012
    Jakob
    ACT
    Canberra
    Quick question, how do I reply with photos in the body of the post, rather than as thumbnails?
    Still waiting on differential parts but I received some goodies from AJPS recently.
Name:	2017-10-02 11.16.01.jpg
    Did some painting on the rear suspension parts, then started working on removing the old bushes.
Name:	2017-10-07 15.47.05.jpg
    Most of them were pretty average with hardened rubber, but these looked like they'd been replaced pretty recently. Should I still replace them with the superpro ones or leave them since they're in good condition? Thoughts?
Name:	2017-10-08 12.03.37.jpg
    Also, I'm missing this exhaust hanger. Does anyone have a spare?
Name:	2017-10-02 11.19.33.jpg
  • #8
    May 2010
    Tyrone
    Caulfield
    Depends on what kind of bushes they are. The superpro are urethane and harder than stock rubber ones so if they're just oem replacements I would probably change them for the sake of uniformity.
  • #9
    Jun 2012
    Jakob
    ACT
    Canberra
    Used a variety of 'special tools' to install the bushes. Old mixer tap and part of an ozito garage vac pipe turned out to be the right sizes to squeeze everything in.
    The standard superpro D bush for the rear swaybar didn't fit. The outside diameter was about 5mm out. There wasn't anything else in the superpro catalogue that looked like it would fit so I ended up with a random bush from Pedders. No idea what it's from but it worked.
    All back together now and off for an alignment in the new year.
    The diff was also built and I've installed it. Very happy with the os giken centre, very not happy with the Weir crown and pinion. It's pretty noisy. Might not matter for a drift application but it's annoying for a street car. The diff shop is going to check it for adjustment in the new year but they're also searching for a second hand OEM 4.3 that will hopefully be quieter.
    I also got new tyres for my TE37s and put them on. Turns out a 15x7 TE37 with a 195/50R15 weighs 0.2kg less than an OEM 14 inch with tyre.
    Should be ready to try for Canberra registration soon. Only two things to do - build an airbox for the pod filter, and fix a random wiper issue. They're returning to upright rather than the rest position. Looking forward to being able to drive it more regularly!
  • Similar Threads
    1. Bloody annoying buzz thru stereo.
      By FoldKing86 in forum Technical - Questions
      Last Post: 4th July 2010, 02:05 PM
    2. Bloody Rats
      By Gilly in forum General Topics (No Technical Questions)
      Last Post: 1st September 2007, 07:19 PM
    3. bloody speedo!
      By _matt in forum Technical - Questions
      Last Post: 30th December 2006, 11:29 PM
    4. bloody volvo's hahahaha
      By boxhed in forum General Topics (No Technical Questions)
      Last Post: 21st November 2006, 12:22 AM
