Results 1 to 6 of 6
Thread: Pulling the display or dashboard out.
    Oct 2017
    Drew
    Raymond Terrace
    Default Pulling the display or dashboard out.
    G'day gents.
    This is probably somewhere further back in the technical questions but since the lurker message won't go away until I write something seems introductions and questions go hand in hand.
    I've got the irritating loose bulb that blinks the whole 86s display out whenever I drive over rough roads - I'm sure I've removed all the screws holding the dash in but it won't come off - anyone know where I can find instructions for pulling the display or dash out?
    West
    It could be the dimmer knob, If I roll mine to a certain point I get a blackout.
    The knee panel comes off. Then the dash fascia unscrews at its lower edge, and then the cluster unscrews from the dash tray moulding with 4 screws. I assume youve already found the three screws above the gauges?
    Oct 2017
    Drew
    Raymond Terrace
    Three small screws were gone when I purchased the car, they were one of the first things I found for the wrong reasons...
    Knee panel -> Dash fascia, screws along its lower edge -> Cluster from dash moulding with four screws.
    Anything I should purchase before my second attempt that is usually busted in the 86s?
  • #4
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I also think it would be the dimmer switch.
    Now this is going back a long time so my memory could be bad with this one: I know it's not legal here but the issue was fixed on my car and a friends by finding the black wire that runs vertically up the right hand side up to the dimmer switch, soldering a wire onto it in the middle somewhere and then directly grounding it. This bypasses the prone to fail dimmer switch and keeps the globes lit up fully at all times. That means that with only a short bit of wire and a soldering iron it ends up being all good, I doubt anyone runs theirs at anything except for full brightness anyway.
  • #5
    Mt Macedon
    It's a classic problem, and there are a few solutions. I just resoldered all connections on the little circuit board in the dimmer switch and everything worked fine again.
    Also to get the dash off, you need to remove the two big nuts that hold the headlight switch and wiper switch into the dash. Pull hte front dials off and you should then see a biggish (17mm??) nut buried in the dash.
  • #6
    West
    I dont have those nuts and my switches rattle. Anyone got spares?
  • Similar Threads
    1. Pulling down a 7afe engine - Removing crank bearing caps
      By Matt in forum Technical - Questions
      Last Post: 15th May 2012, 07:14 PM
    2. Why is my car pulling to the right hard?
      Last Post: 3rd December 2009, 09:33 PM
    3. pulling gearbox out
      By wide s13 in forum Technical - Questions
      Last Post: 17th April 2008, 04:13 PM
    4. Car pulling to the right
      By -=GOODY=- in forum Technical - Questions
      Last Post: 29th November 2007, 09:56 PM
    5. Tips for pulling axel?
      By aaron_drift in forum Technical - Questions
      Last Post: 19th October 2006, 06:02 PM
    Tags for this Thread
