Results 1 to 5 of 5
Thread: Flywheels
    Junior Member RooKi's Avatar
    Apr 2015
    S
    Default Flywheel
    So I'm replacing the clutch on a smallport 4age and was just wondering if I can install a bigport 200mm flywheel and clutch.
    Thanks!
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    The crank bolt pattern is the same, but note that the RWD and FWD flywheels are different for the 4AGE.
    May 2010
    Tyrone
    Also note that if you're installing a fwd 4age into a rwd you'll need the spigot bearing to ensure you don't bend the main shaft in your gearbox.
    Sent from my SM-G935F using Tapatalk
    Apr 2015
    S
    Ahhh I see.
    Thanks guys
    Mt Macedon
    "RWD" is 200mm across the clutch friction surface.
    "FWD" is 212mm.
    I use the inverted commas as early FWD bigports had the 200mm "RWD" flywheel too.
    Both flywheels are interchangeable. But as mentioned, you need to match the clutch to the size of flywheel. And yes, remember to use a spigot bearing if using in RWD format.
    And this info is all over the internet, so a quick search should have unearthed it.
  1. 7a and 4a flywheels
    By McLEVIN in forum Car Parts For Sale
    Last Post: 1st August 2012, 12:16 AM
  2. identify these 2 flywheels ?
    By .ady in forum Technical - Questions
    Last Post: 20th December 2009, 11:01 AM
  3. Flywheels
    By superbmobile in forum Technical - Questions
    Last Post: 10th December 2007, 10:21 PM
  4. 4ac flywheels
    By caps in forum Technical - Questions
    Last Post: 11th June 2005, 02:18 AM
