Results 1 to 2 of 2
Thread: 20v st with black top ecu
    Nov 2017
    omar
    wa
    pasco
    usa
    Default 20v st with black top ecu
    I'm sure it's been asked a million times but does anyone know exactly what ecu wires need changed and what the part number for the map sensor is also the iat sensor
    Sent from my Pixel XL using Tapatalk
    [QUOTE=Elomar88;979148]I'm sure it's been asked a million times but does anyone know exactly what ecu wires need changed and what the part number for the map sensor is also the iat sensor
    Sent from my Pixel XL using Tapatalk[/QUOTE
    the 20vs share the same sensors and ignition , so with the exception of afm vs map sensor they are the same. The pins come out in a different spot on the ecu, so if you can find a blacktop loom I recommend that vs repinning the ecu plugs.
    The map sensor if you use a primary line off the itb’s it’ll work well. I have the ecu pinouts which aren’t hard to follow if you match them pin for pin with the exception of the map sensors
  • Similar Threads
    1. WTB Black top 20v
      By Y-B-NRVS in forum Cars or Parts Wanted
      Last Post: 9th July 2013, 01:05 PM
    2. classic nardi black or silver. pref black
      By .ady in forum Cars or Parts Wanted
      Last Post: 8th December 2010, 03:39 PM
    3. Black on black ONEVIA $11,000 ono
      By cable tie in forum Cars for Sale (Not Toyotas)
      Last Post: 23rd July 2010, 04:36 PM
    4. BLACK on BLACK 86's post them here!!
      By JDMJNKY in forum Offtopic Discussions
      Last Post: 13th April 2010, 01:53 PM
    5. wtb: black top 20v
      By redsprinter in forum Cars or Parts Wanted
      Last Post: 27th April 2009, 05:56 PM
