Results 1 to 4 of 4
Thread: 86 SR5 - having trouble getting it to crank
    Junior Member tipsytoyota86's Avatar
    Oct 2017
    Kristen
    AL
    Shelby County
    United States
    Default 86 SR5 - having trouble getting it to crank
    Hey so I have a 86 SR5 hatch that has 170k original miles on it, have recently started throwing parts at her. Here is what I have done so far:
    Fuel Pump, Filter, and all new lines under the hood
    Rebuilt carburetor
    capped off most of the vac lines
    replaced some blown fuses
    replaced the ignition switch.
    wheel cylinders, master and slave clutch cyls
    EGR delete
    I managed to get it cranked a couple weekends ago. She idled for about 2 solid minutes then died. I had a block off plate made for the left side of the EGR. plugged the right side with a spark plug (could not find a bolt to replace the banjo bolt with, i tried) but the spark plug works well enough.
    Car will not crank. I am not sure what to check now. Only thing I can think of is to buy more vac line, and completely redo all the stock vac lines how the car came originally, instead of capping them off. Any ideas? Anything I can try to narrow it down?
    1. car IS getting fuel and spark! Has compression. Ran for those 2 minutes fine before.
    2. I have not really messed with carbureted cars before, but after a few tries on cranking it, I typically let it sit for a while so I do not flood it when I try again.
    My Current Collection: 1986 Toyota Corolla SR5 "Sweet Pea" 1985 Toyota Supra "Lucifer"
    2001 Toyota Celica GT "Dirty Bastard"
    2000 Toyota Celica GT-S "Race car"
    2004 Toyota Celica GT "Parts Car"
    1989 Honda Civic hatch "Ruby" 1994 Honda Civic hatch "Demonica" 2001 Acura Integra GSR "Linda"
    1973 AMC Gremlin "Gretchen"
    1981 GMC C1500 "Cocaine" (sold)
    1996 Infiniti I30 (everyone needs a beater, right?) "Infiniturd" (sold) 8th gen Corolla coming soon
    Elite rthy's Avatar
    Leo
    Tulla
    Hows the timing?
    Had a similar issues, poured some petrol (like 10ml) into the carby and got the 4ac running
    By the car not cranking do you mean it won't turn over on the starter motor? or yo mean it won't run.
    As the others said , pour a lil fuel into the carby and try that. But also , take the fuel line off the inlet to the carby and see if fuel is coming out.
    Very likely to be the mechanical fuel pump has shat itself, but make sure you grab a hose and put the line into a bucket as if it hits the exhaust and gets hot it is likely to ignite.
  • #4
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    You may also want to verify that the carb float is not sticking and the adjustment.
    Dave W
  • Similar Threads
    1. W58/4a clutch trouble
      By Fashionbmx in forum Technical - Questions
      Last Post: 20th September 2012, 01:02 PM
    2. 20v trouble
      By dodgybrooks in forum Technical - Questions
      Last Post: 10th January 2011, 12:07 PM
    3. picture trouble
      By in forum Technical - Questions
      Last Post: 1st January 1970, 11:00 AM
