Results 1 to 5 of 5
Thread: Intro and First of Many Questions to Come
    Nov 2017
    Kyle
    Texas
    Dallas
    United States of (North) America
    Default Intro and First of Many Questions to Come
    Howdy from the state of Texas! I go by Kyle, and other than wishing for an actual first car, I've got no experience, but do have *tons* of knowledge on maintenance and build from outside sources.
    As for that mentioned first question; How would I go about buying, putting together, and running a street tuned 4A-GE of whichever type, followed by implanting it into a chassis similar in character to the AE86 (Miata NA/Anything else as small/light/"cute")
    Now while I did say I have knowledge of this, I don't have tuning knowledge, so lots of that would be appreciated.
    (PS I feel like an upgraded ~125bhp base 4A-GE would make the norm of Miatas being extra slow changed...despite it still being slower than most after changes are made)
    (PSS I'll take the hate of mentioning a Miata here, but there just aren't any AE86 trims close by...)
    West
    Hi Kyle,
    take your time buy an ae86 when you find one.
    Miata wont appreciate ae86 will.
    Ebay, Techno Toy Tuning, Group 4 Engineering, Toda, HKS, theres lots of bits for ae86
    IMHO buy a GTS and turbo it.
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    kyle welcome
    Join the 4AG club. lots of tuning info.
    Search Club 4AG forum and also AEU86.
    Dave W
  • #4
    Mt Macedon
    I see absolutely no reason to put a 4AGE in a Miata. Unless you just happened to have a Miata with a blown engine and a running 4AGE in the shed.
    Buy a Miata, keep the engine and tune/turbo it. Or look longer/harder to find an AE86.
  • #5
    All engine swaps follow the same process.
    1. Will it fit without modifying the mounts / trans tunnel etc?
    If it doesn't fit, how much cutting or what custom mounts are required etc. The ae86 is fortunate to have many companies that make mounts for most engine combos. Custom tail shafts are easy to get, you provide the measurement from the diff to the gearbox and a shop can make them for you.
    2. What electronics does it need to run?
    Add relays / fuses to power up the ECU and get sensors connected where they need them. There are a heap of wiring guides out there on the 4age motors, they all have the same principals. Power the ecu, injectors, coil / igniter and the car will run. Next is the fuel pump, which in the 4age's case is controlled by the ECU. Then is the charging system/ alternator. And finally the displays on the dash so you as a driver can keep an eye on things.
    3. What fuel system does it need?
    Depending on power will determine the size of the fuel system, in 99% of cases there is no such thing as too big, there is overkill but you should never hurt a fuel system with the appropriate regulators etc. Surge tanks are useful if the car was carby or doesn't have the appropriate baffle in the tank originally. In tank pumps will always be quieter than external ones, but its a personal preference on this. Lines depending on flow requirements you may need to upgrade them.
    4. Is it worth it?
    The answer to this one is almost always no, as you could buy the original car with the motor you are swapping and be pretty happy with it. However, from a self satisfaction and having the car you want to drive of course it is worth it once the car is completed.
    Other considerations to take into account do my local laws permit this engine in the car?
    But usually if you can physically mount the engine, you are 3/4 the way there to making it work.
  • Similar Threads
    1. G'day - new member intro
      By doogs in forum AE86DC Announcements
      Last Post: 2nd July 2015, 08:58 AM
    2. 86 Intro to Drift
      By quoccy in forum Melbourne & Vic Events and Discussion
      Last Post: 5th March 2014, 01:46 PM
    3. Intro
      By Xtra in forum Melbourne & Vic Events and Discussion
      Last Post: 1st March 2012, 09:20 PM
    Tags for this Thread
